  • 4 weeks later...
LOOOOUD NOISES
http://s30.photobucket.com/user/whitesi/media/GTR/gtrdyno_zpssif7jjec.mp4.html
finally got it down to decs at G7 for a full tune.
to my surprise it did pick up more top end power on the same boost.
we did however swap out the boost bleed valve for an electronic one simply because the haltech can manage it itself, but it has given a more stable boost level on high rpm.
so the result before running out of injector room as 277rwkw. we tuned it very slightly back down to 271 because we were above 90% duty cycle.
very similar power curve but just more everywhere and everything as usual coming on allot harder. we had no cooling issues even with hours of holding revs which is nice.
still, not bad for a stock motor, stock turbos.
35fe3d6b-8487-4fa0-959c-a3ed691f969a_zps
compared to the old one at 258
i too it on the SlowLife cruse through the hills and gave it 2 hours of hard time which it oved. god it is so much more snappy. the midrange is amazing.
now time for brakes..... if anything i was rappidly running out of effective breaking power and thats never a good feeling.
also the gtr met its father!
comming from the r31 world... this is a rare find.
Edited by GH05T
  • Like 1
Nah i dont. Just the dynodynamics one.
I get that the readings can be different and especially on a hub dyno. Whats weird is the torque dropped so much from before to after. Sounds dumb but it feels faster than a 10kw change.
Either way its somewhere between 260-270 which is still kinda impressive.
And snappy as f**k [emoji2]
Really keen to get the next engine mde happening.
Keeping it simple
Greddy intake/ cooler hardpipes
Splitfires
Light cams
New -9s
Injectors
Fuel pump and tune again.
But prior to that
Brakes
Swaybars
New coilovers
And .... maby a new paint colour comming....... maby
Edited by GH05T
It does look fun.
I'm not knocking the result, just a shame a direct comparison can't be made. But at the end of the day if it feels faster that's the real test. Dyno can say anything but of it feels slow then it is slow!
I might take it back to paul pavlous who did the first dyno and get as you mentioned a direct comparison.
Maby new colour. .. it needs a respray anyway. I have something in mind. It may eventuate it may not.
Edited by GH05T
  • 5 months later...
trying to fit a nardi wheel, cant figure out the bosskit situation.
the part number for the boss kit i have been supplied is a saas BK190BL
it seems to work well with the steering angle censor, as in the boss kits universal bolt alignment for the nardi sits the censor at 1oclock instead of 12oclock (12oclock being correct for a late model and 1oclock being correct for an aerly model) so thats fine, and the part number is correct for the 32gtr... but its just not deep enough to actually house the steering sensor locators.
does anyone know the correct part for a deeper bodies boss kit?
thats the weird thing, its hicas compatible as in has the provisions for the steering angle parts, in the rigt places...but it just wasnt deep enough.
Sleeka spares have hooked me up with the HKB one for $110, ill grab that in a couple of days and fit her up.
  • Like 1
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
    • Yeah that looks like great caster, but I'd suggest trying less front camber some time and seeing if it helps with braking without reducing mid corner speed too much
    • I ended up setting the rear 5mm higher than normal to give some clearance.  My plan is to run the least camber I can in the rear which I think with the extra width is going to need to be -1.75 to -2.00° just to get clearance.  Guards have been rolled and pulled as much as they can/I would be wanting to.  front has the Acostal knuckle with the KPI change and the drop etc. So should be okay with the existing settings I have run with AR1s etc Front: Toe total -2mm(1mm out each side) Caster +7.5° Camber -3.8° Ackerman +15°
