do you plan to run the 180 or 120 TW?
Sleeka spares have the NS2r 265-35R18 180 treadwear on special for $150 each. very cheap for what they are.
Edited by GH05T
14 hours ago, GH05T said:
just bought 4 from sleeka @ $130 each, fkin cheap man
give me some feedback once you've taken them for a spin, I'm getting some suspension components fitted at the same time I do my tyres so will be a little while off giving mine a run...
20 minutes ago, GH05T said:
Same boat. I need to do brakes, swaybars and probably new coilovers too. Then i can drive fast again emoji14.png
it's a never ending cycle this modifying car business :P
although after this it'll become more maintenance / restoring for me...
finally got my ac sorted, swapped out the ac headunit, apparently there are more than ons size of front fascia, had to do a swapover from my old unit.
also used some plastic polish on the surround, brought back that satin shine :P
  • Like 3
Did you know if you hold down the "Lower Temperature" button for 5 seconds it goes into "FC" mode which is basically about 16 degrees..
Try it and enjoy :) Also highly recommend getting the condenser fan wired up to turn on as soon as you turn on A/C.
  • Like 1
You can also hold the "High Temperature" button for 5 seconds and that goes into "FH" (Fast Hot) mode. I used to say "Fkin Cold" or Fkin Hot" lol.
  • Like 1
huh did not know that.
also when i have the ac unit out i replaced the shitty bulbs for leds for button illumination, jesus f**king christ thats a frustrating job. the little f**kers just do not come out. they un twist and go loose, but dont just fall out. i have to destroy each and everyone one to get them out.   sooo not a fiddely kinda person.
Yeah, you just need to change the temp to 18 or 32 then hold the temp button for 5 seconds. It'll go into "FC" or "FH" mode. It's handy in summer when you want to freeze or in the winter when you need to heat the cabin up fast. If you watch the servo motor operate under the dash, you'll see just how far it moves either way.
I found it easier to remove the front face held in by 3 screws to remove those pesky globes. Massive pain in the ass though.
Edited by jmknights93
  • Like 1
  • 6 months later...
lol.
cmon though, brand new v8 TD LC79 isnt exactly a shitter though, im kinda proud of my new daily :)
it had 400km on it when i dunked it up to the bonnet in salt water hahaha
  • Like 3
    • Stock ECU (or more accurately stock tune) absolutely refuses to go over 10psi and behaves like you have seen. The Nistune is the same if it is the stock tune. If the Nistune chip has been tuned, the resulting tune could be literally anything for any combination of parts. The Nistune just makes the stock ECU Tunable.
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
