Hey all,
Was wondering if any GTR yodas could she'd some light on the subject. Bought a GTR recently and was told the car had upgraded garrets but not sure on size.
Pretty tightly packed on the exhaust side of the gtr as you guys know. I need someone to help me identify what it is I have on the car.
What I do know:
- They have a .64 rear
- has Garrett on the front covers
- noticed a tag that says ARMS on the front cover. Can't see much but on the tag it also says RB and an A engraved/stamped under it. Reallllly tricky to try and get a pic.
Anywhere else I should be looking?
Thanks in advance
https://www.sau.com.au/forums/topic/452970-what-turbos-do-i-have/
http://www.nengun.com/tomei/arms-b7660-turbine-kit-nissan-rb26dett
again without seeing the tag we cant say that these are your turbos as alot of very different turbos look very similar
thanks man...
did some digging and found this...
Tomei B7655 (173011) 47.7 55T 0.42 T25 T25 47.0 76T 0.64 BB ~500PS
Tomei B7660 (173012) 47.7 60T 0.42 T25 T25 47.0 76T 0.64 BB ~600PS
Tomei B9046 (173013) 51.7 46T 0.42 T25 T25 53.6 90T 0.64 BB
~700PS
http://homepage.ntlworld.com/tbroom/Turbos.htm
looks like i will have to remove some stuff to get to the tags to confirm..
Seems as though they are Tomei variants. not finding a lot of info on it. car makes 260kw atw at about 14-15psi. stock ecu.....
Edited by WantGTR
If they are Tomei.
Commiserations... Just search "ARMS" here on the forums and you'll see they are not the best performing twin configuration, they are almost the worst. They are better than factory though in that they wont break. So that's good news :)
  • Like 2
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
