Hi i've had my nm35 for a few months now & the tailgate wont open. I have to open the glass part & reach in to up it. I've been told i need this part. But the thing is im in the uk where there is not many m35 stagea's over here. any help would be great on getting the part i need.
1911980_10206159734379343_65969572775398
It's the one with the part number 90500n
https://www.sau.com.au/forums/topic/453475-m35-tailgate-wont-open/
This happened to me once. ended up being a blown fuse. I cant remember the exact location of this fuse, but the fuse boxes are located at drivers side foot area and in the engine bay in front and behind the battery. In case you don't, you can manually open the tailgate from the inside. there is a small panel that you can take off where the tailgate latch is, which will expose the latch. Goodluck
the importer i used to get the stagea is fixing it & had it apart as they said it was the button that was't working put a new button in still not working. but have now sorted the part from nisswreck but spent a few hours last night email people on ebay to see if they had the part
  • 4 weeks later...
here's my story.,, mine never opened i tried and tried and even the previous owner of my 2002 Stagea said its never opened its never worked id checked the fuses in the fuse box located next to drivers right foot and they were all fine so today i tried it again i simply unlocked the car (as you do) put my finger on that button pressed in and held the button and pushed with my other hand the glass inwards instead of just pulling and then it opened ! now it works!! it opened to my amazement and then i was hoping it would close again and it does so simple try it again ! might be your lucky day as it is mine
the fuse for the glass tailgate is a 10 amp and is located on the bottom right of the fuse box next to the drivers foot
i have got the translation for the fuse box in detail i will post
mine never worked then i managed to open it 10+ times and know all of a sudden (after cyclone pam) my glass tailgate wont open again ., really annoying i tried taking of the plastic bit on the inside where the latch is and tried cleaning,drying everything compressed air to blow shit away but nothing works so i might replace the fuse and hope its just that., whats the story can u put a 15 amp fuse where a 10 amp should be ? would this benefit in any way
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
