2. run a tank of 98 every now and then to clean out the fuel system and avoid gummy buildup in your fuel system
How often do you guys fill up a tank of 98 to clean it?
United have very rapidly raised their prices, I have been considering getting my car retuned back onto 98 so I can get some kms per tank again since I'm not seeing prices as low as they used to be at the pump, it's a joke how much they've raised it.
its not really united, its now ethanole is trading on the same market as oil so market price is set along side oil price so varys as much when it shouldnt as its an entirly different economy
http://www.agmrc.org/renewable_energy/ethanol/ethanol-gasoline-crude-oil-and-corn-prices-are-the-relationships-changing/
This sort of explains it, basically instead of being set separately to oil prices all together as it should be the bulk ethanol prices actually is dependent on crude oil prices.
Making it not as cheap as it should be. Can't find the original article I read saying it's now being set the same way the parity pricing agreement with oil works.
From my understanding of ethanol, I wouldn't bother with a tank of 98 to "stop it gumming" as Ethanol is a solvent, which means it will actually clean out the gummy build up, as well as help clear up carbon build ups etc.
No point whining about it, I heard every excuse for not running e85 in Sydney over the years, it's too far away to fill up, Caltex e85 isn't consistent, not enough servo's to run e85 daily...
If more e85 was being sold they would have put more pumps in, end of story. I used to drive 22k's each way to fill up, in the snow with bare feet.
  • Like 1
They need to open a united servo with e85 in Sutherland shire
Doubt they will until Caltex pull their Eflex from kirrawee. So easy for everyone to fill up there on their way to the nasho
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
    • Hi @Chupapy i had several leaks from coolant pipes being corroded, i also had one leak on back of the head onto transmission. For me that leak was from the turbo water line. Follow the line to the back of the head The hose and metal pipe had perished these are the best pics I took of it at the time
