2. run a tank of 98 every now and then to clean out the fuel system and avoid gummy buildup in your fuel system
How often do you guys fill up a tank of 98 to clean it?
United have very rapidly raised their prices, I have been considering getting my car retuned back onto 98 so I can get some kms per tank again since I'm not seeing prices as low as they used to be at the pump, it's a joke how much they've raised it.
its not really united, its now ethanole is trading on the same market as oil so market price is set along side oil price so varys as much when it shouldnt as its an entirly different economy
http://www.agmrc.org/renewable_energy/ethanol/ethanol-gasoline-crude-oil-and-corn-prices-are-the-relationships-changing/
This sort of explains it, basically instead of being set separately to oil prices all together as it should be the bulk ethanol prices actually is dependent on crude oil prices.
Making it not as cheap as it should be. Can't find the original article I read saying it's now being set the same way the parity pricing agreement with oil works.
From my understanding of ethanol, I wouldn't bother with a tank of 98 to "stop it gumming" as Ethanol is a solvent, which means it will actually clean out the gummy build up, as well as help clear up carbon build ups etc.
No point whining about it, I heard every excuse for not running e85 in Sydney over the years, it's too far away to fill up, Caltex e85 isn't consistent, not enough servo's to run e85 daily...
If more e85 was being sold they would have put more pumps in, end of story. I used to drive 22k's each way to fill up, in the snow with bare feet.
  • Like 1
They need to open a united servo with e85 in Sutherland shire
Doubt they will until Caltex pull their Eflex from kirrawee. So easy for everyone to fill up there on their way to the nasho
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
    • Yeah, shame. Maybe  driver's carpet is available 🙏. I am waiting for both amayama and nangun to confirm.
