Before you spent too much on an RB20, consider an RB25 or RB30det, when the $$$ start flowing you only have a 2L as your base.. :yes:
Ive thought about that but the cost of legally doing that here in Japan, the price is crazy. Have to go thru special registration, cost of having it put in, wiring, and pay extra money and have it re-inspected, etc. Also my road tax will almost triple.
The shop I spoke with about tuning the car once I decide what to do, suggested a 2.4 litre kit with a rb26 crank.
So I might just go 320-350 hp, and see how that is. If I want more than I will research more and maybe do the 2.4 litre kit.
Also I wasn't planning to buy a larger throttle body. I see them often over here on the car parts sites for the rb engines so I was wondering if anyone actually changed theirs.
Edited by yoshiii335
We've already lost that argument with him. Apparently, this one time, at band camp.....I mean, in Japan, it's too expensive to use a 25.
Oy, as I said in the other post, if you dont have anything positive to say, please exit the stage.
I definitaly wouldn't stroke the 20.
Go 25 or just enjoy what the 20 will give you after some mods.
Stroking it will cost a lot, get less power and response than a 25, still have a weaker gearbox etc...
Definitely a no-no.
Definitely a no-no.
Definitely a no-no.
Ok, I wasn't sold on the idea.
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
