What do you call "settled"?
I am sure that many people do make 450kw with the stock rods - maybe more - and some may have failed at less.
Why is high revs a no-no? Lots of RB26 fans will say spinning them at 9 or 10k is the fun part.
If you have a question such as " I want to build a 450kw Rb26 and won't rev it over 8K - do I need to replace the stock rods?" you might get some useful answers.
Im waiting for the threads that are about to follow this one.
Like the how many Kw can the stock pistons and rings, or rods or bearings take.
Better still lets start a how long is a piece of string, thread.......
70kw's all day every day at 9krpm each. Why do you wish to know. Pretty pointless thread. If the motors apart for the $600 bucks a set of forged H BEAMS are you wouldnt bother with the stockers.
Do the bolts always break first, or are the rods failing too?
Good question also curious. You see people occasionally fit arp bolts and having to resize the rods and rebalance with aftermarket pistons. The $$ probably comes out similar to cheap forged rods that come with arp 2000 bolts
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
