TD05 is a smaller turbo than TD06. In Garrett terms think of them as T25 or T28 vs T3 frames. Although they don't line up the same as those, the change in frame size is what's important.
16g, 18g, 20g are progressively bigger versions.
Roy uses his car on the track though...I'm not sure a TD-05 or D-06 RB20DET is going to be that much fun on the street.
For the street the smaller HKS turbos are going to be more responsive.
LOL, my car is a street car first, track car second and is a huge compromise on the track because of it. What makes good usable power on the street makes for good usable power on the track. Its not like a slow street car will make a good track car!!!
A TD05-16G may work ok but frankly...lottery dip stuff.... IF you are going to go anything after your RB25 turbo its a GTX2860 or grab a used 2530.If you are going to spend the money dont do it with one arm tied behind your back. Like i said, dont tune the RB25 turbo setup and go straight to the better turbo and you have just saved yourself the difference between a cheap lottery dip turbo and a better turbz that will give you a good result. But i get the reason why the poster wants to run his RB25 turbo for a while.
The 2530/2860 is a good bolt on option...but dont think its massively more responsive than a bigger turbo that is a proper full setup. All different dynos and tuners but here are a bunch of plots but reckon it paints the correct picture
the hks and garrett turbos arent looking a whole lot more responsive in terms of power but they boost up much faster than the other turbo's, and in the power graphs the garrett has got about 20kw's more than the hks turbo in top end, garrett turbo is definitely seeming like the way to go although i would like to find out more about the kinugawa turbos because if i can get similar performance to the garrett turbo for $400 less i'll take it in a heartbeat
So cliff notes. TD05 and TD06 are referring to the turbine type and size. 16G, 18G or 30 , 25G are all referring to the size of the compressor.
So, if you are going std internal gate bolt on turbo I personally would stay away from anything as big as a TD06. That is the same size turbine as I am running and can make 300-330rwkws. So waaaay over what you are after and in turn will be bigger and heavier for the exhaust gas to spin so...laggier than you need
So the compressor side of things...if you go for as late a model 16G based turbo you will be in the window of the power and response you are after.
IMO stay away from 20G or even 18G as the 18G is really the same size as the 20G , just a different trim. So again on 98 fuel it is a 270rwkws turbo.
So, for me and what I understand your needs to be...I would be looking at getting Kando to price up the following turbo for you.
T3 TD05H turbine housing
http://www.ebay.com.au/itm/Kinugawa-Turbo-Turbine-Housing-Nissan-Skyline-RB20DET-RB25DET-8cm-TD05H-T3-/271807706353?pt=LH_DefaultDomain_15&hash=item3f490074f1
Cartridge
http://www.ebay.com.au/itm/Kinugawa-Turbo-Cartridge-CHRA-TD05H-Small-16G-Oil-Cooled-49178-54700-46-60mm-/271531508287?pt=LH_DefaultDomain_15&hash=item3f388a023f
And run a 2/4" Compressor cover.
Effectively that is an old EVO turbo
If you want to go to basically an 18G sized wheel, just the smallest trim then get the 16G6 (in Mitsubishi world they call it a Big 16G)
http://www.ebay.com.au/itm/Billet-Turbo-Compressor-Wheel-Mitsubishi-EVO-3-TD05H-16G-48-30-68-01-mm-6-6-/291401525948?pt=LH_DefaultDomain_15&hash=item43d8e26abc
And run that with the T3 Skyline housing from above. DO NOT take thei std T3 turbone housing as they are POS! ie this
They are horrible on the exhaust side for flow
They are just spreadsheet dumps of peoples dyno sheets over the years. God it was from about 2004-2005 :( So there are differences in dyno types, dyno operators adn importantly wheel sizes. The rolling diameter of a 16" wheel is a lot smaller than an 18" so if going by road speed you can think something is more responsive than it really is because of the smaller wheel size.
So, the important take away IMO is arming yourself with a reasonable expectation and then speak to your tuner. Your tuner is paramount and get them to show you different graphs all from the same dyno so you can compare apples to apples.
If you are in your states SAU club jump in cars and go for rides. And lastly, dont rule out the Hypergear turbos I guess. From what was posted his T3 offering for his SR20 turbo is a bit of an abomination with buts welded on here and there to make work, but if there are some good results out there for an RB20 then it should be on your consideration list. But the RB20 result he posted was not all that promising, though that may be that particular car and not the turbos fault
From RB20 dyno results thread
1993 R32 GTST
Stock RB20DET
TD05-18G (EG 8cm)
Nismo 555cc (with GTR Resistor Pack)
Nistune
3" Turbo Back
Walbro 255
FMIC
Z32 AFM
United 100 RON
Stock engine, stock manifold, stock cams/gears..
With some cam gears dialled in you woudl expect to pick up a little bit in response. Not sure what T3 housing he has
OP's asking for a good bolt on turbo for his R32, by reading this thread there are whole lot of unrelated information that I'm confused.
The photo shopped result contain a mixed batch of E85 results, pump results, externally gated results, internally gated results, cam moded, plus results of a NA+T Rb25.
Filtering out all the unrelated. Take unopened Rb20det engine on pump fuel. I'm seeing hypergear's atr43ss has the best curve which made the most power on based boost level given. Turbo is direct bolt on that required little/none modifications, that will be the turbo I will be voting for.
I would personally go for the 2.4" compressor cover, rather than the 3" anti-surge cover. But importantly they are the wheels and turbine housing to go for
Just scrolled through the RB20 dyno results thread. The Hypergear turbos all seem very laggy, but there are so many versions of the things perhaps they are older versions
Hypergear OP6 Hiflow may be more suited to an RB25
Stock RB20
HyperGear ATR43SS1 (none PU version) turbo internally gated bolton to stock manifold.
3" Turbo Back Exhaust
Nistune tuned
Pump 98 Fuel
FMIC
480cc Injectors
Bosch 040 Fuel Pump
3inches hard intake pipe with Pod
227rwkw (green) @ 18psi
It doesnt seem a bad option if you want a bit of headspace
FJ1600s results
92' gts-t
Stock Internals - SSS Automotive Wrecker Engine
Bosch ev14 750cc injectors
Z32 AFM
Walbro pump
Sard FPR
Red jacket coils
Bellmouth dump and 3' exhaust + decat
GRedy Profec B II
FMIC
Hypergear RB20 Highflow Turbo
PULP 98
224.8kw on 17psi
Stock RB20
RB20 Turbo Hypergear Highflow
Nistune tuned on V-Power 98 Fuel
GTR Intercooler
555cc Nismo Injectors
Walbro Fuel Pump
Splitfire Coil Packs
Greddy Profec b Spec II
Stock Airbox and KN Panel Filter
201rwkw @ 20psi (High), dropping a bit to 19psi and 174.6rwkw @ 14psi(Low). Did 206 with the cat removed, but the engine started pinging as the timing got advanced, so had to leave it with the 201 tun
They are the same A/R so not likely to make a big difference. 3" means more changes to inlet piping vs std vs 2.4". But more importantly there is reason to believe anti-surge covers take a bit away from response so 2.4" is easier to package and make look std. If you go 3" just go std 3", not anti-surge
Few RB20det owners buys a high flowed Rb25det / Neo turbo and replaces their blown Rb20 standard turbos with it. Those high flows are not made for RB20det motors. It will be very laggy. And not so relevant.
We usually run a different combination of wheels for RB20det standard turbocharger high flows, those are Rb20det "high flowed" turbocharger results.
and
For power and response, its not bad for a high flow using stock housings.
The current ATR43SS1 per the black back ground read is made for a Rb20det, it makes reaches full boost about 4000RPM, and makes 227rwkws @ 17psi. That is turbo is engineered for a Rb20det engine, that bolt on to your factory manifold, dump pipe, and all lines.
My Rb20det dyno readings are limited, Based on SR20det, the response of a SS15 is slightly laggier to a GT2860Rs but more responsive then GT2871R. This turbo is also efficient enough to peek 281rwkws on pump fuel at 24psi internally gated. Taking accounts if installation, response, power to boost ratio, and ability of performance gain on future modifications. This is a my recommendation.
Anti surge comp cover reduces surge issues, which you are unlikely to see that on a RB20det motor. It also reduces power to boost ratio in some cases. I don't machine surge slots in unless there is a surging problem.
its going to be much more effort to get all the pieces individually and have a turbo made rather than just buying a kit ready to bolt in, on a td05 16g will the anti surge really make much difference? because its just much less hassle to buy the kit and bolt it all in and that kit by the sounds of things is perfect for me except for the anti surge part, my intake piping is already 3" so thats not really a problem either
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
    • Literally looks like direct port nitrous haha
