Damn, should have put my name down earlier.
Let me know if any spots become available.
Hi Mate,
As a back up plan you can always do Nth Circiut with us -
http://www.sau.com.au/forums/topic/457132-18th-october-smsp-north-circuit-interclub-track-day-limited-offer/
So far 6 or 7 of the guys from this track day are in! :yes:
Just out of curiosity and cause I've never been to a track day before. What does everyone bring?
in my case, a tow truck.
but srsly, a seat, bottles of water, some food, any spares or tools you think you may need.
And of course, helmet, and suitable clothes.
Hey guys I know a lot of you are not new to track days and will know what I'm talking about but for the newbies I will be outlining what will be expected when you come see myself and others in the scrutineering shed
First things first empty your car of all loose objects, don't want to have things rolling around in the car
This will include the drivers floor mat for worst case scenario of it catching on the pedals.
While we are inside we will check your seat belts for condition, standard belts are fine no need to splash out for a harness but each to their own
Fire extinguisher is next which will need to be securely mounted WITHIN REACH of the driver, which means if you cant reach it while seated it needs to be moved.
Also make sure your fire extinguisher is within the green band on the gauge for obvious reasons
There are guides floating around the forum of where and how to mount in skylines
Next up is checking for any leaks present on your vehicle
This is pretty self explanatory, make sure there is no oil, water, power steering etc leaks present otherwise no tracks for you
At the same time we will be checking other components within the engine bay to make sure everything is in a roadworthy condition and doesn't present a hazard
Battery will be checked next for security so it won't move under super late braking and super crazy g forces
Factory restraint is fine for this
That basically covers the car now we move onto YOU!!
We check that you are wearing clothes that cover you from ankle to wrist so long pants long sleeve shirt closed shoes (sorry mateetee no hot pants and heels)
At scrutineering we will be checking your helmet is Australian certified should have a silver and sticker AS1698 eg
This is minimum standard
And make sure it is in good condition no cracks etc
If you have any questions feel free to PM me and I'll try help you out
See you all on the day in the scrutineering shed!!!
  • Like 2
Thanks Nick, that's the post I was actually looking for :)
Hi Mate,
That looks good!! I'll have to see how money is going next month. Very keen if I can afford and fit it in.
  • 3 weeks later...
Get on it!
List is now full again. Reserve spots only.
Get your payments in and PM me your info, if you haven't already. We need your info to help with groupings for the day.
Check your membership card expiry dates, motorsport license etc. and let me know when payment has been sent and I will confirm back to you that it has been received.
Full Legal Name: (as entered on bank deposit)
Forum Alias:
Car Make:
Car Model:
Experience: (New to Track Days) (1 or 2 non-timed events) (multiple events with timing)
Times: (List track & official time, e.g. Wakefield 1:13 SMSP 1:08 etc)
    • yeh they are 235/45/17 up front and 255/40/17 in the rears. I still didn't get my answer if i can fit a 18x9 up front. I want to get 4 of this and see if they will fit before committing as they didn't see an 18x8 as an option but there is a 18x9.5 also.   Enkei RS05-RR 18x9 35mm ET 5x114.3 75.0 Bore Matte Gunmetal Wheel
    • This. The R34 handbrake icon DOES come up when the brake fluid level is low. You might be sitting right on that threshhold. I have been down this diagnosis path and this was the solution (and it was pretty much as full as your picture is to begin with).
    • Unfortunately the cavaet to that is that while any scan tool should be able to read the code, the workshop will need a consult plug to OBD socket adapter. You don't have a location on your profile, where are you based?
    • @Haggerty this is your red flag. In MAP based ECU's the Manifold pressure X RPM calculation is how the engine knows it is actually...running/going through ANY load. You are confusing the term 'base map' with your base VE/Fuel table. When most people say 'base map' they mean the stock entire tune shipped with the ECU, hopefully aimed at a specific car/setup to use as a base for beginning to tune your specific car. Haltech has a lot of documentation (or at least they used to, I expect it to be better now). Read it voraciously.
    • I saw you mention this earlier and it raised a red flag, but I couldn't believe it was real. Yes, the vacuum signal should vary. It is the one and only load signal from the engine to the ECU, and it MUST vary. It is either not connected or is badly f**ked up in some way.
