Not that I care, but when modifying a car it has to all meet the ADR standards.
No changing can allowed, no more than a 20% more power etc.
There's something about changing to an older engine somewhere, which is a no no, but given an rb30 comes out with one cam, using a different head and cams although stock, is still changing the cam.
That's easily sorted by an emissions test though.
The 30 bottom end and 26 or 25 head is a bit of an oddball as far as the standards and law goes.
Agree this setup is perfection ^^^ if i was to go a single it would be very similar.
All will get sorted. Just needs time.
Nice to hear there is some hope among the gloom :)
I know I will be happy when it is done and love the way it drive already, I think it will be a good hill climb car.
The old set up was crap compared to how it drives now, even with the existing problems I am happier :)
Illogical statement.
It was crap because the set up for your previous engine was crap.
That's why you are having the issues now because you are using the same suboptimal setup for your new engine, which is crap right now. Right?
Logical isn't it?
Not having a go at you, just saying now you have the knowledge that your set up from when you bought the car was suboptimal you know why it drove the way it did. Don't ignore the elephant in the room when you are critiquing your previous setup.
Anyway all the best with it and I hope you get exactly what you want and even better than what you expect. :)
Logical isn't it?
What previous set up are you referring to , 1 when I bought it, 2. when I changed the cams, turbo and exhaust 3 the 3.2 and this one is not finished yet and when it is I expect it to be what I wanted to begin with, fingers X :)
Here are the 3 dynos
So do you have a pic of the harmonic balancer ?
Cause if it is in fact controlled by the factory CAS that could be the issue :(
I picked that the build will require a crank trigger to sort out timing issues ages ago....
Those where the pics i've been looking for
Doesn't look like it has a trigger wheel :(
Factory CAS could very well be the issue :/
I hope not but I've seen it to many times
what problem does this cause
Timing scatter at high RPM due to the longer timing belt, this is the problem when an engine is controlled by what is realistically a rubber band
My advise now is DO NOT push this engine till the problem is confirmed just in case cause timing scatter can cause big problems
thanks for that, could have saved me a bigger problem, didn't need anymore :)
Glad you said that I was going for a run today and I have been too busy with the kids for a while.
I will ask them if they ut a trigger wheel on
Pete you'd know if they did, it would be on the bill. Until the murrayis kit came along they were not cheap.
Not on the build sheet or the earlier build before I bought the car, just the ATI balancer and damper ??
Do they make that much difference or more a safety precaution for the motor ?
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
