Not that I care, but when modifying a car it has to all meet the ADR standards.
No changing can allowed, no more than a 20% more power etc.
There's something about changing to an older engine somewhere, which is a no no, but given an rb30 comes out with one cam, using a different head and cams although stock, is still changing the cam.
That's easily sorted by an emissions test though.
The 30 bottom end and 26 or 25 head is a bit of an oddball as far as the standards and law goes.
Agree this setup is perfection ^^^ if i was to go a single it would be very similar.
All will get sorted. Just needs time.
Nice to hear there is some hope among the gloom :)
I know I will be happy when it is done and love the way it drive already, I think it will be a good hill climb car.
The old set up was crap compared to how it drives now, even with the existing problems I am happier :)
Illogical statement.
It was crap because the set up for your previous engine was crap.
That's why you are having the issues now because you are using the same suboptimal setup for your new engine, which is crap right now. Right?
Logical isn't it?
Not having a go at you, just saying now you have the knowledge that your set up from when you bought the car was suboptimal you know why it drove the way it did. Don't ignore the elephant in the room when you are critiquing your previous setup.
Anyway all the best with it and I hope you get exactly what you want and even better than what you expect. :)
Logical isn't it?
What previous set up are you referring to , 1 when I bought it, 2. when I changed the cams, turbo and exhaust 3 the 3.2 and this one is not finished yet and when it is I expect it to be what I wanted to begin with, fingers X :)
Here are the 3 dynos
So do you have a pic of the harmonic balancer ?
Cause if it is in fact controlled by the factory CAS that could be the issue :(
I picked that the build will require a crank trigger to sort out timing issues ages ago....
Those where the pics i've been looking for
Doesn't look like it has a trigger wheel :(
Factory CAS could very well be the issue :/
I hope not but I've seen it to many times
what problem does this cause
Timing scatter at high RPM due to the longer timing belt, this is the problem when an engine is controlled by what is realistically a rubber band
My advise now is DO NOT push this engine till the problem is confirmed just in case cause timing scatter can cause big problems
thanks for that, could have saved me a bigger problem, didn't need anymore :)
Glad you said that I was going for a run today and I have been too busy with the kids for a while.
I will ask them if they ut a trigger wheel on
Pete you'd know if they did, it would be on the bill. Until the murrayis kit came along they were not cheap.
Not on the build sheet or the earlier build before I bought the car, just the ATI balancer and damper ??
Do they make that much difference or more a safety precaution for the motor ?
    • Yeah I've had too many issues with knock off's on the BMW's. I don't want to do a job twice or more because the parts are shit.
    • I read this and thought "ah! I will do this scissor jack on the tow point thing!" I just use my floor/low profile/costco jack and lift the car up by the tow hook itself, then slide jack stands under. Never thought about using scissor into floor jack combo :p
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
