Not that I care, but when modifying a car it has to all meet the ADR standards.
No changing can allowed, no more than a 20% more power etc.
There's something about changing to an older engine somewhere, which is a no no, but given an rb30 comes out with one cam, using a different head and cams although stock, is still changing the cam.
That's easily sorted by an emissions test though.
The 30 bottom end and 26 or 25 head is a bit of an oddball as far as the standards and law goes.
Agree this setup is perfection ^^^ if i was to go a single it would be very similar.
All will get sorted. Just needs time.
Nice to hear there is some hope among the gloom :)
I know I will be happy when it is done and love the way it drive already, I think it will be a good hill climb car.
The old set up was crap compared to how it drives now, even with the existing problems I am happier :)
Illogical statement.
It was crap because the set up for your previous engine was crap.
That's why you are having the issues now because you are using the same suboptimal setup for your new engine, which is crap right now. Right?
Logical isn't it?
Not having a go at you, just saying now you have the knowledge that your set up from when you bought the car was suboptimal you know why it drove the way it did. Don't ignore the elephant in the room when you are critiquing your previous setup.
Anyway all the best with it and I hope you get exactly what you want and even better than what you expect. :)
Logical isn't it?
What previous set up are you referring to , 1 when I bought it, 2. when I changed the cams, turbo and exhaust 3 the 3.2 and this one is not finished yet and when it is I expect it to be what I wanted to begin with, fingers X :)
Here are the 3 dynos
So do you have a pic of the harmonic balancer ?
Cause if it is in fact controlled by the factory CAS that could be the issue :(
I picked that the build will require a crank trigger to sort out timing issues ages ago....
Those where the pics i've been looking for
Doesn't look like it has a trigger wheel :(
Factory CAS could very well be the issue :/
I hope not but I've seen it to many times
what problem does this cause
Timing scatter at high RPM due to the longer timing belt, this is the problem when an engine is controlled by what is realistically a rubber band
My advise now is DO NOT push this engine till the problem is confirmed just in case cause timing scatter can cause big problems
thanks for that, could have saved me a bigger problem, didn't need anymore :)
Glad you said that I was going for a run today and I have been too busy with the kids for a while.
I will ask them if they ut a trigger wheel on
Pete you'd know if they did, it would be on the bill. Until the murrayis kit came along they were not cheap.
Not on the build sheet or the earlier build before I bought the car, just the ATI balancer and damper ??
Do they make that much difference or more a safety precaution for the motor ?
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
    • Since winter isn't that harsh anymore in Poland, i will definetely drive it 365 days a year 😉. But if the snow hits i will try it for sure and let U know. Only swap i am planning to do is of course R34 GTR front 😍.
    • Hey. Very valuable information about pitwork, I will pay attention when buying any consumable parts 🙏 As for the carpets - I got a handful of information from nengun, from which it appears that indeed the carpets for the driver's side are OEM. They are not able to show me any pictures due to the long chain of different sales entities but after I place the order, as soon as the goods arrive at the nengun warehouse from which they will send the shipment to me they can send me photos and if my purchase differs from OEM I can immediately return it / cancel the purchase. I think I will give it a try 😉. Of course i'll let you know what's what as soon as i get them P.s. I know the topic is not relevant to the thread, but both nengun and amayama have these SICK 😍 trunk room lamps available. Do you know anyone who ordered them? I need to have one in my car
    • I've managed to find this: Nissan_Stagea_AutechVersion260RS (1).pdf
