Leave the poor guy alone. I would also be very edgy after everything he has gone through with this car.
True. Sorry mate.
Sometimes a bit of friendly banter gets taken the wrong way if your not in the right frame of mind.
But the main thing is that Pete beat the Tiida .... That's the main thing even at 10000 rpm. Would have sounded awesome.
  • Like 1
Bit angry today Pete
No mate, its all good fun :)
I have never said I was any type of gun driver, I just like cars :wub: had a 911 and a TT300zx I used to push a bit, but I was a kid, 50 year old.
Everyone has their preferences , mine is a car that dives like a street car, one that has a bit of grunt from down low.
Do not need 3000 idle Ben, is that how you blokes do it. Me at 2500rpm and want to get it going in any gear drop down 1 gear and away you go, LOL
But serious it is great on the twisty stuff, so much fun. Not sure you could do the same on tight one lane roads with a T88 or something else that gives you 700 or 800 peaky HP, but I can only guess as I do not drive fast GTRs , just my heap :)
My car is the best fun you can have sitting down, well , a lap dance maybe ?
True. Sorry mate.
Keep the banter coming mate, that is what makes the Forum fun, farken love it :banana:
Have you got your car back yet Pete?
Not yet James, had an email this morning saying it looks like the leak has been fix but they will do some more tests over the next couple of days to be sure .
Not sure if they will be doing a new Dyno graph , soon see I guess ?
Things are looking up :)
  • Like 1
At 70, I hope to be a much much more bitter and twisted old man than you. Pretty sure I am now at half of 70.
Oh don't worry mate , I was very bitter and twisted at 70 but now I am 73 I have matured , guess it comes with age , LOL
Just thinking to myself.... I feel more anxiety over and your car in than my own. Ha ha. Ha. Might have to drive up from Melbourne so you can take me for a spin when you get it back.
HAHA, that's why I have chilled, I left the anX to you. I lie , I had / have enough anxiety for the both of us. It's been a long 9 months :)
And it's not over :/
Edited by Nismo 3.2ish
They are probably just putting the head back on now pete, takes more than a few days to strip a motor again, lol... :ph34r: apprentice stuffed up again..
Thanks Mark, now my head is exploding thinking about anther 5 months getting the motor re built :bomb_ie:
No problems, I will be picking it up VERY soon and looking forward to a little spirited driving to see how it is running :)
Got a date for pickup? Good RB30 blocks are getting harder to find.
They are going to do a few more tests and I should know by Friday :)
Just hope I got one of the good ones, they did all sorts of tests on my RB30 block, like below
ENGINE MACHINE WORK INCLUDING HOT TANK BLOCK, ACID
WASH , BORE AND HONE , BALANCE ENGINE COMPONENTS.
DECK BLOCK, MACHINE BLOCK FOR O/S HEAD STUDS,
MACHINE WORK FOR AWD ADAPTOR AND ENGINE BRACE KIT.
MACHINE SUMP RAIL TO TRUE UP ENGINE BLOCK.,RELIEVE ENGINE BLOCK FOR 3.2LTR STROKER ENGINE.
1.000 SONIC TEST AND XRAY ENGINE BLOCK TO TEST FOR SUITABLITY
Sounds like they did their best
    • Hi guys . Can someone help me  I bought an Android screen for my Nissan fuga but it won't turn on
    • My guesstimate, with no real numbers to back it up, is it won't effect it greatly at all.its not a huge change in position, and I can't see the air flow changing from in turbulence that much based on distance, and what's in front of it. Johnny and Brad may have some more numbers to share from experience though.
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
