haha, thanks
Hope I do not get too bored too soon, well the builder should get bored before me, he had it longer :)
When you get bored just put a bigger turbo on it. Response gets boring quickly.
I will look out for your next thread, titled ' I love my car BUT its missing something' ha ha
I think you should relocate that number plate just quietly.
And I hope you don't have another misfire. That would be beyond a joke
I like it there, no obstruction for the air and you do not have to bend it at each end to go into the original position , a lot of Plates look like they have been nailed on, see great looking Rs and shitty plate positions and conditions ?
Not worried if it is missing again, I am not going back to Sydney and I am sure I will find someone closer and go from there.
Shit mate if everything worked the thread would closed and my life as I know it is over :(
Just watch this spot mate, I might have to steal your name for the thread :)
I never got sick of a car with response and have been loving response for over 55 years, but it took about 2 klm to hate lag and want to sell the car.
Big turbos are exciting and I am sure my car would be great with a big modern turbo, that is, if I could ever use it :/
Each to his own mate, just got to love cars and driving them :cheers:
Old wives tale........ You can always use it..... He he ....... Always. :D
haha, but getting it up to 7k and dropping it at the lights or out of Woolies car park is not a good look, fun no doubt but is frowned upon by the boys in blue :)
Where is the RPM on that Graph?
Is it 300kw just under 4000rpm?
Max torque is extremely early - beauty of 3.2L ay.
I want to compare my graph - same power just .6 of a L down.
Edited by Stixbnr32
Mmmmmm, some falsely say it is the case. Never had to do it myself. I think people talk a lot of shit really, or just don't know how to drive.
The next tune I have done will have RPM and you will bet a comparison , I find these Dynos without the rpm to be a pain. I will try and have the few things I need done ASAP and it should be interesting to see if they can do more with the tune and cam dialing ?
Is there anyone reading this that can put the revs to the KPH.
Paul was saying that I have lost 5.2KW but at 18.5psi not 22psi on the last tune , as you can see the psi drops off from 24psi @ 351kw and makes full power @ 18.5psi of 381.7KW, so I guess it really did not loose anything with the new dump ??
Stuffed if I know how it works :/
Looks like your making the same power with less boost. That's a result of a better dump (good thing)!
Also what Hadouken is saying may also be true, the spark could be blowing out which is why there is now less boost.
If this is the case there's an easy solution to this problem.. It's just more $$$
You might be right about the driver , me :)
I had a T78 so not a new age turbo but it was hideous as a DD , but I guess we all have our own idea of lag for a STREET CAR, " not track or hill climb." as I know shit all about this type of driving, but I know once the revs are up they are great.
Turbo is too small. Turbine housing too small which restricts flow and chokes the engine. In this scenario you have no choice but to cut boost.
It will be interesting to see what an e85 tune does because if it makes no significant difference then the turbo selection is the problem.
  • Like 1
New coil pack ?
Interesting that the boost tapers of so much, would be alot better if it could hold.
What wastegate and what boost controller peter?
He said he cut the boost , but I do not understand that as the last tune was 22psi and this was at 24psi to kick off and dropped off to 18.5 psi?
I put the PT6262 CEA Turbo on it as a 2.6l, left it there to see how it goes.
Personally I do not care what E85 does , I cannot buy it here, just like having the option and would love to feel the difference from pump .
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
