So, bit of an update;
My compression test is being done this Saturday as well as my drive belts as they need replacing too
Wish me luck on the compression test! :wacko:
Will then move onto the Diff Gasket + Diff Oil Change!
Will also need to speak to a painter as I have just found about 2 small (Tiny) rust spots on my bonnet, would like to get that done asap as rust spreads like cancer!
If all goes will with compression I will be buying a Pulsar as a daily :yes:
If not, will use my money to help get the car fixed! :P
So bit of an update.. sorta :P
It's only Tuesday and I'm super nervous about the compression test, I really do hope all goes well!
Anyways, just thought I'd share with you guys my goal - Look's wise for the car
Only thing am adding is a roof spoiler & possibly wider rear guards :w00t:
Otherwise this is exactly how I want her! and I didn't realize it but I'm almost there :)
  • Like 3
Oh, and I'll keep my spoiler!
No GTR spoiler for this GTST :nyaanyaa:
Plugs were already changed the week it started having this issue, so they should be all sweet! :thumbsup:
gtr rear spoiler. not bad looks nice.
youll be right mate :D you getting new plugs put in whilst there doing it anyways? ahha
Thanks JH32!
Glad to see people are reading it, enjoying it and giving feedback! :D
Yeah, it just looks weird haha and not aggressive enough for me!
Cheers mate, hoping for good results :)
Nice build mate, good to see you having a good crack with the gtst. I much prefer the series 2 rear spoiler over the series 1 :)
Good luck with the compression test!
So on Saturday as well as doing the compression test I got my drive belts changed
Good thing too as they looked pretty worn!
Lucky my best friend is a mechanic and he came prepared with a shit-load of tools haha!
Drive belts were all done pretty easy :banana:
Oh, here is an engine bay shot too :D
So now came the nerve racking part, the compression test!
All looked ok up until Cylinder 6 came up, it came up with a reading of 90 :/
This was the one I was most nervous about as I had been reading that is usually the cylinder that plays up as it doesn't get as much airflow going to it and gets the hottest
So we did a wet test and dropped a little bit of oil into number 6 and the number still stayed, which means it could be the Valve Stems or a Head Gasket
So that was some good news at least!
So I ended up buying a new head that day from one of my good friends :thumbsup:
Visually it looks ok and no cracks etc can be seen but I am taking it into HeadTorque on Saturday to get it checked over, serviced and re-machined
Will be buying the new Gasket's from Nissan hopefully this week or next and then will get the head done
I will then be swapping my heads over! Good news is I get to put a better Head Gasket on and some nice ARP Head Studs :D
Will also hopefully be buying a Pulsar this week too so I don't have to drive the Skyline as much
I will update this on Saturday :laugh:
Although I am upset, I am looking forward to this as it will be a good learning experience taking the engine apart etc and it's good to have a qualified mechanic there to help me learn things along the way! :)
Bit of an update.. sorta :P
Yesterday I bought a 2000 N15 Nissan Pulsar Sedan! I couldn't resist another Nissan and I only paid $1,400 for it and it was in pretty good condition :w00t:
Excuse my mate's Cef -Cough- Camry -Cough- :rofl2:
This trusty steed will be taking my 25 Head to HeadTorque tomorrow, so will update then :yes:
Edited by MC-WOSHY
So update time for those of you listening it at home! :laugh:
I took my Head to HeadTorque (Would highly recommend them for anyone in WA!) on Saturday
They took the Head out and measured it all up.... and..... It's all good! yaaay :D
The head is perfectly straight and not warped in any way.
All the Head needs is to be taken apart, serviced, cleaned up and the installation of fresh bolts, so I thought I was all sweet
Key word there being "thought" but as with anything, something had to go wrong :down:
The Head I had originally bought, turned out to be a NEO which meant it would have too high compression to be attached to my block :mad:
So I am in the process at the moment of finding a S1 RB25DET Head, which I should be picking up this week :yes:
The guy who is selling it was nice enough to allow me to get his Head checked out before I purchase it, so that's awesome news as I'll know exactly what I'm dealing with :)
In other news, I have half of my Gaskets. So now I just need The Intake Manifold Gasket & Exhaust Manifold Gasket which I'll be getting this week and then soon I'll be getting some ARP Head Studs and a Head Gasket (Thickness depending on how much HeadTorque takes off the Head).
Here are the Gaskets - Cam Cover Gasket, Cam Shaft Seal & Half Moon Seals (Not pictured, but you know what they look like!)
What would the comp ratio be with the NEO head? If you're not running a heap of boost and the comp ratio was under 10:1 then I wouldn't think it would cause too many dramas.
Maybe someone with more NEO knowledge can chime in and be a little more specific.
In all honesty I don't know too much either man
Hopefully someone with knowledge sees this and chimes in!
I just heard it wouldn't be too good from a number of sources so I thought better to be safe than sorry :unsure:
Ok guys, update time!
This week I managed to get the last bits needed for the head. I bought the Intake Manifold Gasket and the Exhaust Manifold Gasket :D
Now all I need is the Head Gasket, just need to wait to see how much HeadTorque takes off the Head so I can buy the appropriate thickness Head Gasket :laugh:
Oh, and some ARP Head Stud goodness!
In other news, I also bought the correct Head this week! I managed to chase down an RB25 S1 Head and I've dropped it off to HeadTorque just now for a check-over
More updates will come then :yes:
I am seriously contemplating buying Tomei Poncams with my Tax-Return in 1 month though :glare:
Thanks for reading this far guys! Hope it's been good so far :thumbsup:
  • Like 1
Looking great mate, good job :)
I am thinking of doing something with the inside as soon as I sort my motor out, if ever :/
should of bought my head, already had cams in it :no: ,
If I were you id slap the neo head on and add some water meth, would be very ballsy motor plus the cam has 8.5ish lift and zero hydraulic lifters to make noise later.. ;)
Cheers mate! I'm glad you enjoyed the read :thumbsup:
It's good to see people reading and actually like this thread, in all honesty I didn't think it would be that great to others! :teehee:
  • Like 1
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
    • Why are you so adamant on going M12? Why not follow Brad (GTSBoy) suggestion. You're talking moving from a 1/8" size, to a 1/2" effectively. 4 times bigger. Why skip the commonly available sizes in between? The bigger you go, the more likely you are to strip the threads out at a later date, as guaranteed, someone will put a huge spanner on the M12 and really tighten it up, and you're only in thin wall, so not a lot of threads to engage!
    • Hi. Yeah thanks. Car is already at tuners and it staying there to resolve "many" issues they do not like. So it is in a good hands. Getting a good tune on that Nistune ECU too so the car would be good. Just needs a little tune up and love.
    • Probably gonna remove manifold and turbo. I’m not sure if I can get M12 x 1.5 air tight. Could use high temp Loctite 246 or something similar, but I don’t know. Maybe it’s just best to remove everything again and weld an 1/8NPT on there instead.
    • Yeah, saw the ratios, not impressed. Would like the punch I have in the first gears now. With those ratios it won't be the same.  Also want the h pattern gearing, or at least a quiet gear set that don't need to come apart for service each year. Looks like the only "reasonable" way Is a 8hp70 transmission, but where is the fun in that🤷‍♂️
