I have had coolant poor down from behind the engine somewhere and passing down onto the ground generally when the car gets to temperature. . Rather than replace heater hoses which i think is the issue. I want to delete the heater all together. Is it a big job?
Just join the two pipes going through the firewall into the heater core on the engine side. Pull of a hose and get something like a brass plumbing pipe from bunnings that matches perfectly and cut to size and clamp the two hoses that would otherwise run into the heater core together. Will solve your leaking issue if your heater core is in fact the problem. Getting the heater core out of the Dash is a much bigger job from the inside.
Edited by sonicz
I just want to delete the heater hoping that is the problem.. what else could it be? Btw I have checked inside the car drivers side and passenger no signs of coolant leaking inside.
Edited by boobeedoobee
If it's not leaking inside then the leak is in the engine bay somewhere. Try as sonic and Ben have already stated and if it's still leaking you will have to find the leak. No other way around it.
Generic 1m lengths of oil and water hose isn't expensive, and by the sounds of it they will need replacing regardless.
If it is leaking behind the engine then you really have NO CHOICE but to find the hose back there that has a hole in it and replace it. And of course, because all the other hoses back there are old and crusty, you should do them too.
Deleting the heater would be a counterproductive effort that would take the same amount of effort as just fixing the problem.
  • Like 1
by the sounds of it you have a leaking hose which may or may not be a heater hose, I suggest finding which hose it is and replacing it.
If it was the heater core that was leaking the water would be inside the cabin
Ok thanks ill replace the leaking hose which your right might night be a heater hose. Just wondering though before I go and buy a heater hose kit..as I will be deleting the heater will this eliminate the need to replace the heater hoses?
Ben is there a way if getting around that after deleting the heater?
There are options, electric heater fan things for that very reason. I don't think j they actually work particularly well, but they satisfy the law.
I feel like in the time you've spent asking for ways aroung the way around, you could have just organised parts to fix the problem
I changed all my heater hoses with a Greddy copy plenum a few weeks back. Was a pain in the ass, but only took about 2 hours to replace all 4 heater hoses. Stop being lazy and fix the car rather than putting everything in the too hard basket.
Ok thanks heater delete it is.. save future leakage problems. Less hoses less trouble. I've never actually used the heater and never will. Wasn't trying to be lasy. Just needed to know what parts to organise depending on which way i went with it. Air con will go also
Google heater hose diagram rb26 and then decide on what you would like to do. Whether that may be replacing all hoses (I would do this) or cutting and blocking the heater hoses. It's one of the first things kids learn while driving around in beaters. Heat and plastic doesn't mix well after 10+ years.
    • From my youth: GTi-R clutch change is a massive pain. The gearboxes are fragile? But the car is super cool and I want one 😢
    • Remember this is 1988 tech.
    • Driveline vibration is resolved. I ended up loosening all my engine mount and trans mount bolts, giving it a good shake then retightening everything and it's gone... Let's just say I was surprised that fixed it.  I've been happily driving it around again but unfortunately put zero time into my direct port/constant pressure WMI setup. I'm on vacation next week, so I'll try and finalize it then.  On a different note, I spent all week fuel/ignition mapping 2x 216L V16 engines. Turbo's were burning glycol and we swapped them out for larger units. We also had planned emissions testing on site, so I figured I'd be there the same week to use their instrumentation and massage any emissions issues out if needed. This was a first for me. Fuel management is similar in certain ways to automotive (i.e air density as load variable) but very different in others. It's all PLC based and AFR's are controlled by air and not fuel. They use a control valve between the turbo and air manifold to control pressure which in turn controls AFR's. Due to this, target AFR tables supplied by the OEM are in pressures and not mass which really through me off. They use air pressure vs fuel pressure tables. I also relied on an O2 concentration sensor the emissions team had in the exhaust. Ignition timing was also all over the place and we were losing a fair bit of power. They're now happily sitting at 16-40BTDC depending on load. We were making about 1600kw at 900rpm at 90% load. Engines were running a lot smoother as well.
    • heh, aint no R32 ever meeting modern targa cage rules unless the driver is veeeery short OP, good luck with the sale, since its already in the land of freedom I'm sure you will find a good buyer.
    • meh, it was a good video, clear about the issue and how he dealt with it. A bit heavy on the RTV and very brave to put an RB in anything without rebuilding it first, but otherwise I thought it was good Dose, I'm not sure that having the pickup forward is a big issue; yes of course the oil could shift under brakes but the sump should never be empty enough for that to be a problem (unless you also have a higher volume oil pump, and that oil can't return from the head to the sump quickly enough)
