Hey all
Bought over the weekend this R32 gtst, manual. Now no laughing!!
Just to let you know i got it cheap! CHEAP! Runs well and drives nice.
Has more stickers on it then ive ever seen and to make things worse they have cleared over the stickers! and the pics dont do justice to how many stickers there are on the car!! but anyway!
Another problem is, its running duel fuel. Yep, 98 and direct LPG! actaully runs well on lpg....
Anyone ever seen LPG on a rb before??
anyway. the interior is not to bad just need to replace a few things.
Didtch the body kit on it, lower it and chuck on some wheels.
Just looking for a nice non defectable daily.
Have started chasing parts
Paint will come later
11072496_10155518900265215_8764080191540
11148592_10155518900195215_7138532922615
  • Like 2
https://www.sau.com.au/forums/topic/456114-daily-r32-gtst/
Haha yer im unsure at this stage what ill do... take it off is the long term plan.... short term is to dig in and get it looking presentable, because it runs and drives really nice.
But all of this has to be done on a budget, and most will be done by my hand.... May have bitten off more then i can chew! As the pics make the cars interior and body work better then what it is! Yes really!!
Edited by Adz2332
https://www.sau.com.au/forums/topic/456114-daily-r32-gtst/#findComment-7525617
Yep thats this weekends job. pulling out all the white stuff sanding and painting. matt black?
Also pulling out the seats, front and back as carpets look good but will get the steam cleaner into it... and the speakers etc are a mess! so again will pull all the speaker stuff out and put some of my own stuff back in.
https://www.sau.com.au/forums/topic/456114-daily-r32-gtst/#findComment-7525626
I'd be tempted to paint the trim gloss metallic black.
Grab a couple new vents for the dash... and a stock GTR wheel.
... aaarh bodywork. maybe smooth it off and wrap the car?
gloss might have a look. wait till ive fixed them and rubbed them back etc
Ive always wanted to have a crack at spraying... but thatll be long term.
Vents are a pain to come by!
Strip the whole thing and track it.
hahah already have a track car
Think the 32 has 4x4 springs in it!! lol
Edited by Adz2332
https://www.sau.com.au/forums/topic/456114-daily-r32-gtst/#findComment-7525727
have 2
  • Like 1
https://www.sau.com.au/forums/topic/456114-daily-r32-gtst/#findComment-7525730
might be selling/ giving away 32 gtst seats soon, also might be selling my 17x9+22 enki wheels with good tires.
if you keen ill let you know when.
i have a spare stock handbrake boot too.
how do the rims sit? would be interested if they dont poke... dont want to be defected lol. main MAIN aim for this car!
https://www.sau.com.au/forums/topic/456114-daily-r32-gtst/#findComment-7525883
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
    • I hear that would involve some nice country road drives into the hills for Mark...
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
