9 hours ago, t_revz said:
Define “blew out”
Was driving home from work, turned onto my street, had 0 power on acceleration.  Engine "shook" got power back, but there was so much smoke blowing out the exhaust that I looked like I was doing the sickest burnout ever.
When I pulled into my driveway the idle was terrible the engine was shaking, I turned her off, tried to start her again and she wouldn't.
she spent 2 days at C-Red and they told me that 2 cylinders lost compression, the oil line to the turbo split and the turbo blew up too, and the head gasket went as well.
While they were looking at her she seized up completely.
Bummer. Part out or fix? At least it made it home for you.
Fix it then possibly Sell and try break even.
23 hours ago, t_revz said:
Sounds like the oil line blew and it ran without oil pressure
What turbo does it have?
What’s the plan?
Stock Turbo. It was just an old, high KM Engine, remember the car was parked up in a Trucking yard with no Rego for years and had a very questionable past.
So now I'm looking for a new engine which, these engine are stupidly expensive, and I'm going to sell my old engine to anyone who'll take it for maybe $500...
*joins the queue for a 20 year old seized nissan import engine with dubious history and blown turbo*
I was told there would be cake?
Wait. There was supposed to be cake? I never got any cake when my 25 ate it's bearings. I feel ripped off.
  • 1 month later...
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
