I was going to sit and study for exams, but then I thought that's boring so I changed the coil packs. The car is so much smoother, idle's smoother and quieter and revs quicker too. Another thing ticked off the list.
I havnt forgotten about this thread of the car, im now working full time during the week as well as part time on the weekends. I want to work on the car but got no time....hopefully I can put aside some time to keep working on the car.
Also my first DIY got approved so have a look, give me feedback :rolleyes:
Small amounts of time on my hands now. So I decided to add some rice, therefore added some LED lights in the footwells. They turned out pretty well actually. Not sure if a tutorial exists but if someone wants one, ill write one up...well I'll probably write one up anyway.
Edited by shubby0901
  • 3 weeks later...
Thanks guys.
I had plans to get an exhaust made before christmas but the muffler I want was not available anywhere, so now I will probably get it done around the end of January due to work and travel before that.
So over the weekend I attempted to fix the passenger side mirror as it doesnt fold in. After pulling the whole thing apart and thinking the gears are jammed, I pulled them out cleaned them, bought new grease and greased them up and reinstalled them...only to have it still not work... :yucky:. Mirror had to be reinstalled as I need to drive to work tomorrow. On the hunt for a mirror which has a working folding mechanism to swap it out now.
Greased up gears:
In the process of removing the mirror, I smashed the tweeter when I didnt realise it as hanging and closed the door. Luckily it was only the casing so I thought what better excuse to properly mount the tweeters.
Went from this (ignore the missing door card)
24fc5ddf-17f6-4fe7-ab2d-59f8a6c9e719_zps
To this:
6e97d29e-c3ff-4fa1-8190-7d271541c798_zps
I call it a success and it makes the interior look so much nicer.
Hey mate - You will find the issue isn't the gears rather its the contacts in the switching mechanism in the mirror. Happened to me and I used this guide to fix it:
http://www.sau.com.au/forums/topic/93178-r33-electric-side-mirror-repair-s2/
Shortly after I fixed the passenger side, the drivers side went and I haven't been bothered to fix it lol.
GL - Tweeters look nice like that
  • Like 1
Hey,
Yeah I thought this initially but when the switch is pressed the motor make noise and both if the mirror is open or closed, the whole system doesn't work, anyway i ran out of time to try the contacts solution so maybe next time.
  • 1 month later...
Got the car back. Exhaust sounds awesome!!
Specs: Catback Stainless Steel 3.0" with Varex Twin Tip muffler connected straight to battery.
I will record a video and upload it soon.
7c2e8e96-28b7-4adf-bb9d-3c05ea2461d2_zps
  • Like 3
The twin tips look pretty neat on the car. *thumbs up* So simple yet so nice.
Thanks man.
Following your thread too. Love the front bumper, skirts and pods on your car. #Goals haha
  • Like 1
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
