Hi guys,
Hoping for some thoughts on this.
i've replaced my factory radiator with a new 40mm alloy radiator and now my coolant temps don't want to go above 75 C.
i've been reading up about replacing the clutch fan with electric but i'm happy with the clutch fan for simplicity (street driven car)
bearing in mind its winter here in NZ, should i just not worry about this and suck up the slight increase in petrol consumption or are there any alternatives?
i was thinking perhaps an R34 thermostat instead of the r33 thermostat?
i'm not opposed to electric fans either.
cheers
https://www.sau.com.au/forums/topic/456949-new-radiator-now-better-cooling/
Just try a new R33 thermostat first. Many years ago I did on my RB20 exactly what you just did. Only replaced the rad because the end tank cracked - not because (I thought) I had inadequate cooling. The result was that the coolant ran cold and I used a heap of fuel. Put a new thermostat in and the problem went away.
What was actually happening is that the old thermostat was actually no good - stuck open, and the radiator was also not real good. Must have been part blocked or something. It wasn't doing enough cooling and the two of them together were actually keeping my coolant temperature in about the right range. Replaced the rad and threw that precarious balance out!
  • Like 1
I bought a new 82c thermostat and it's clearly 65ish in the real world. I wouldn't be surprised if the Nismo thermostat is actually the 'new' standard thermostat that gets sold.
At least that's whats happened to me... from buying new thermostats trying to get one that's better/higher/more suitable? than the 65c one that seems to always end up in my car.
.. different radiators, too.
What's the idea of a lower temp thermostat? It doesn't increase cooling capacity at all and at best would buy you an extra lap maybe 2 if you're having heat problems
For the nismo whores.
Sort the real issue out, don't band aid it.
Nismo thermostat runs a higher temp but your right, a normal thermo should still operate properly.
why would it run a higher temp? lol
R34 thermostat opens at 82 degrees so your water temp will be close to 90
R33 thermostat opens at 77 degrees so your water temp will be close to 85 or so
I prefer to run a lower temp one simply because when you're on the track there's a greater range before water boils. I'm using a 62.5 thermostat lol... but that's no ideal for a street car because your oil temp is too low (even if you have an oil thermostat as the oil temp is relative to the water temp due to the heat exchanger).
Also R32/33/34 thermostats are the same size... I made the mistake of fitting a R34 GT-t thermostat in my R33 and kept on scratching my head on why the water was always close to 90 degrees.
  • Like 2
what water temp are you trusting here?
stock sensor and gauge?
In my case, stock sensor and gauge, aftermarket sensor and gauge, and the ECU temp sensor and gauge (via the ECU program)
I got an oil temp sensor and gauge specifically to see what my oil temp was, because I was certain it either wasn't 65C, or if it wasn't... to find out what it was.
I put a Nismo Thermostat in my R33, it now sits bang on 68 degrees no matter what, until I start putting my boot in. Then the koyorad keeps it below 95c even after 4+ hot laps on the track...
Only issue is it is TOO cold... my tuner had to adjust the powerfc water temp adjustment data, because he was needing to spend time on the dyno trying to warm it up so it would be running in the correct parts of the maps for power.
i've replaced the thermostat with some success, the temp now comes up past 75 and makes it to 78 but stays at 78, this is good i guess, its winter and pretty cold here at the moment so i won't worry about the enrichment, haven't given it a death thrash yet....lost a bit of skin on my knuckles changing it....
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
