OK spark plug, cam and timing belt covers sold. Still for sale:
6 Volk Racing Le37 in 18x9.5 +12 $2,500
Wideband 02 sensor controller $180
Battery Box $20
2x 32 Heater core and box $80
JJR RB26 sump baffles $250
R34 GTT/C34 Stagea Series 2 Oxygen Sensor $90
Ruzic Datalogger and Engine Monitor II $500
Plenum $200
Walbro e85 fuel safe pump $200
  • Replies 43
  • 3 months later...
Walbro fuel pump gone.
Now added, radiator cooling panel to suit W34 Stagea from the original Bass Junky group buy, $150
So the current list of for sale is:
Battery Box $20
RB26 Plenum $200
Stagea Cooling Panel $150
Sorry yes the plenum is bare other than the air temp sensor; although if you need particular bits I probably have them...
Re the Ruzic Data logger.  Basically Paul Ruzic (Mountainrunner on here) was (is?) a skyline owner and electrical engineer who built limited runs of a couple of excellent units.  I'm selling the Engine Monitor and Data logger, they work together to monitor 23 channels of data, and bring them to your attention if there is an issue (eg low oil pressure, high oil or water temp etc etc).  It comes with software to configure each of the inputs.
When an alarm is triggered you can get warning light and/or buzzer, it also comes with a shift light and the EM has a configurable screen than can show 4 pages of 4 values.
You (or an auto elec, or a good workshop) will need to wire in whichever data you want to log. I had oil temp and pressure, coolant temp, fuel pressure, revs, volts, speed, rpm, 4wd%, afms, air temp, injector%, timing, TPS, wide band 02, brake switch, engine check light. And GPS location and speed of course
Available channels for the Engine monitor:
Available channels for the Data Logger:
The 2 units share data so all DL channels can trigger warnings, and all EM channels can be logged.  It logs to a USB stick for easy changes and transfer to a PC
There must be a few engine monitors out there because I got one from the second batch, not sure how many data loggers he made.  Also his attessa controller (which I don't have) is excellent and links in too.
When I decied to go e85 with flex fuel I went Haltech, as part of the change I went to their dash as well to keep the car simple.
  • 2 months later...
lol, you mean other than a major PITA?  I'll check something out but I don't have access to anything other than retail couriers
  • 3 months later...
  • 3 years later...
46 minutes ago, RobsgottaGTR said:
I am interested in the wheels!  Ready to purchase.  Message me here or on Instagram @robs_gotta_gtr
PM sent!
  • Like 1
Yeah it's been a while, but not everything is sold...I need to recheck everything and probably just start a fresh thread
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
