OK spark plug, cam and timing belt covers sold. Still for sale:
6 Volk Racing Le37 in 18x9.5 +12 $2,500
Wideband 02 sensor controller $180
Battery Box $20
2x 32 Heater core and box $80
JJR RB26 sump baffles $250
R34 GTT/C34 Stagea Series 2 Oxygen Sensor $90
Ruzic Datalogger and Engine Monitor II $500
Plenum $200
Walbro e85 fuel safe pump $200
  • Replies 43
  • 3 months later...
Walbro fuel pump gone.
Now added, radiator cooling panel to suit W34 Stagea from the original Bass Junky group buy, $150
So the current list of for sale is:
Battery Box $20
RB26 Plenum $200
Stagea Cooling Panel $150
Sorry yes the plenum is bare other than the air temp sensor; although if you need particular bits I probably have them...
Re the Ruzic Data logger.  Basically Paul Ruzic (Mountainrunner on here) was (is?) a skyline owner and electrical engineer who built limited runs of a couple of excellent units.  I'm selling the Engine Monitor and Data logger, they work together to monitor 23 channels of data, and bring them to your attention if there is an issue (eg low oil pressure, high oil or water temp etc etc).  It comes with software to configure each of the inputs.
When an alarm is triggered you can get warning light and/or buzzer, it also comes with a shift light and the EM has a configurable screen than can show 4 pages of 4 values.
You (or an auto elec, or a good workshop) will need to wire in whichever data you want to log. I had oil temp and pressure, coolant temp, fuel pressure, revs, volts, speed, rpm, 4wd%, afms, air temp, injector%, timing, TPS, wide band 02, brake switch, engine check light. And GPS location and speed of course
Available channels for the Engine monitor:
Available channels for the Data Logger:
The 2 units share data so all DL channels can trigger warnings, and all EM channels can be logged.  It logs to a USB stick for easy changes and transfer to a PC
There must be a few engine monitors out there because I got one from the second batch, not sure how many data loggers he made.  Also his attessa controller (which I don't have) is excellent and links in too.
When I decied to go e85 with flex fuel I went Haltech, as part of the change I went to their dash as well to keep the car simple.
  • 2 months later...
lol, you mean other than a major PITA?  I'll check something out but I don't have access to anything other than retail couriers
  • 3 months later...
  • 3 years later...
46 minutes ago, RobsgottaGTR said:
I am interested in the wheels!  Ready to purchase.  Message me here or on Instagram @robs_gotta_gtr
PM sent!
  • Like 1
Yeah it's been a while, but not everything is sold...I need to recheck everything and probably just start a fresh thread
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
