  • 3 weeks later...
Hey, just sent you guys payment. Don't know my old membership number unfortunately, will it be a new number or the old one. Can you send me the membership number as I need it for an event I wish to enter. Thanks. :)
On 9/5/2016 at 11:36 AM, Humbla said:
payment made 22nd of August, form emailed as well.
Thanks Genelle, both have been received and being processed, planning to post a batch out tomorrow. :)
  • 5 weeks later...
  • 1 month later...
Hey guys, are renewal reminders supposed to go out? I didn't get anything if they are set. Thought I'd check my 1st order last year to find out the date of when I joined and it was this week last year. I'll send through the renewal tonight :).
On 11/16/2016 at 6:13 PM, seanski96 said:
Just applied and payed for membership on the 16/11/2016
Happy to become a member of SAU finally!
Hey Sean, thanks for joining and welcome to the club!
Hey Mark, We run a normalised expiry date (30/6 & 31/12 depending on join date), so your membership will expire on 31/12/2016. Saying that, while you're thinking about it, if you do decide to renew early this will just push your membership expiry to 31/12/2017. :)
Cheers,
Mathew
  • Like 1
  • 1 month later...
  • 3 weeks later...
Many thanks Mathew, got my card and lanyard yesterday.
Love ya work and thanks for giving me my old fart members number back "15/923" and many thanks for the added bonus.
Cheers
Neil.
  • Like 1
  • 4 weeks later...
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
    • OK, if it idles at 1000+ with the AAC, its not an idle airflow problem. The cold start valve just gives extra air when the engine is cold, but you have enough air without it to idle at 1000. I think you are back to a fuel problem, sorry. Can you see the fuel pressure staying constant or does it drop as the revs drop to a stall?
