Ok first a bit of history
I bought the car in 2003 it came with the usual exhaust and pods and beyond that was pretty much standard, i replaced the fuel pump and had the factory ecu remapped and made a respectable at the time 235kw at the wheels
In 2004 I sold the car and stayed in contact with the new owner, come easter 2007 the owner decided he wanted to part with it and after a check over the deal was done.
Over the next few years it stayed basically mechanically the same but got fitted with a set of r33 brembos and a new set of wheels DSCN0097.jpg
In 2011 the engine finally let go and after dramas with the engine builder I lost interest in the car and it sat outside, untouched for about 3 or so years. Eventually I bought and fitted a stock r33 engine, removed the hicas and fitted another set of wheels BE45199B-21D6-4332-A0D8-DFF69E14B8B2-334
So here we are today and I've finally decided to do a build but won't be anywhere near as big as the previous one was. The goal for this build is to make 373kw (500hp) at the wheels with as close to standard response as possible
Now on to the build
First things first after sitting around for so long, with my little helper I replaced all the oils in the car 38715BAD-0206-4564-8071-EAA643FC9322.jpg
Then took it up to jez for a baseline run so that we know where I'm starting from and know how far I need to go8DDD7264-F675-4601-8890-6964AD4070D8.jpg
So here we are with the baseline and a plan in place that I will reveal as the build continues
  • Like 5
https://www.sau.com.au/forums/topic/458011-r32-gtr-long-term-love-now-project/
I'm going to try and keep the updates weekly in order to stop the thread/build going stale, not everything will be a performance upgrade, there will be some general refreshing and tidying up as well. But there will be photos and information of everything that gets done along the way
This won't be a do everything in one hit build, it's also not going to be a slap a bunch of crap together and hope for the best. It's going to be a very thought out and have a few things a lot of people either wouldn't do or wouldn't think of
TBH it's very hard to find info on E85 and -7's.
i just said stuff it and we will find out. Tuner thinks 350-360 on E85 and they will run out of puff. Will report back when she is finally fixed though. Can't wait to see what you will do man!
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
