It has midori dump pipes, 2x70>Into 80mm front pipes (not sure of brand as rage was missing) 3in 100cel cat and a hks cat back (the one with the huge mufflers in it.
But of corse for curiosity sake when I installed it i had a look down the exhaust and being a jasma exhaust it came with a free resrtictor in the center muffler
I had always intended to replace the exhaust anyway as I was never happy with how low it was and It didn't sit up in the rear bar how I would have liked
So now it's going to get a fully custom made stainless steel one that hugs right up into the body
Only a little update this time, I took the exhaust off the car and took it for a drive (I'm sure the neighbors were real impressed lol) and it reved clean and it made power!! luckily the next job was always going to be exhaust, so me and my mate will be building an exhaust for it ASAP
Also the car has decided to leave it mark around the place and that will be the next little job that also needs doing, is power steering and transfer case oil
  • Like 1
Also turns out the leaks on the power steering are form the feed line to the pump and the transfer case is the speedo seal, so will order the o ring for that and do the actuator seal while I'm at it. The power steer line I will probably make up a custom one using dash fittings
Sorry haven't up dated this for a couple of weeks but was crook and then had things to do to the house,
I've only done a really small thing to it. Basically I've never liked that the superlaps don't have center caps and got some adaptors that allow me to fit some
Went from this
And ended up with this
  • Like 2
  • 3 weeks later...
Another small job this week, the boost gauge has been an eye sore for a while after the bracket broke
So a trip to skyline spares and a little money later I was able to buy a second hand bracket and fit the gauge in it. Looks a lot better, it's amazing how the little things can make a huge difference
sorry for the terrible photos but it was dark inside the garage
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
