It has midori dump pipes, 2x70>Into 80mm front pipes (not sure of brand as rage was missing) 3in 100cel cat and a hks cat back (the one with the huge mufflers in it.
But of corse for curiosity sake when I installed it i had a look down the exhaust and being a jasma exhaust it came with a free resrtictor in the center muffler
I had always intended to replace the exhaust anyway as I was never happy with how low it was and It didn't sit up in the rear bar how I would have liked
So now it's going to get a fully custom made stainless steel one that hugs right up into the body
Only a little update this time, I took the exhaust off the car and took it for a drive (I'm sure the neighbors were real impressed lol) and it reved clean and it made power!! luckily the next job was always going to be exhaust, so me and my mate will be building an exhaust for it ASAP
Also the car has decided to leave it mark around the place and that will be the next little job that also needs doing, is power steering and transfer case oil
  • Like 1
Also turns out the leaks on the power steering are form the feed line to the pump and the transfer case is the speedo seal, so will order the o ring for that and do the actuator seal while I'm at it. The power steer line I will probably make up a custom one using dash fittings
Sorry haven't up dated this for a couple of weeks but was crook and then had things to do to the house,
I've only done a really small thing to it. Basically I've never liked that the superlaps don't have center caps and got some adaptors that allow me to fit some
Went from this
And ended up with this
  • Like 2
  • 3 weeks later...
Another small job this week, the boost gauge has been an eye sore for a while after the bracket broke
So a trip to skyline spares and a little money later I was able to buy a second hand bracket and fit the gauge in it. Looks a lot better, it's amazing how the little things can make a huge difference
sorry for the terrible photos but it was dark inside the garage
    • Cheers. Skyline is back on the menu, can’t get rid of it. It’s like a child you don’t want, or herpes
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
