Been a bit slack the last couple of weeks but have been doing a lot of parts gathering IMG_4991.thumb.JPG.b403a9eed0b78edebb9ec2dbdba69302.JPGand here is the result of my collecting so far, after working out the fuel system wasn't going to be up to the job I decided to go all out
First thing to get fitted was the kit the tank hat belongs to
IMG_4998.thumb.JPG.bc8c290289b0a21eee1cf9ed223b25e0.JPGIt comes with a baffle to help prevent the fuel surge that's common in these cars
IMG_4999.thumb.JPG.7fddcc2619e8b91bf71ac52d50bc5c3a.JPGwith a bit of wiggling it slides into the tank and clips in where the original pump does
IMG_5001.thumb.JPG.a0be8caaaec23d3f9baf4f86f582435f.JPGand holds two walbro 450 pumps that will be staged IMG_5002.thumb.JPG.448feb2f67ae92984dac01fc19425027.JPGand the pump and hat assembly ready to go in to the tank, the kit also comes with a new sender for the gauge
that is an awesome setup....solves so many annoying problems.  are you happy with how will the new baffle/mount fits into the tank's original plastic holders to stop everything moving?
  • Like 1
There's is a little bit of movement once it's all clipped in but nothing to be concerned about, I had to remove it back out of the clip when I dropped a nut while installing it and there's no way it's coming out by itself
Speaking of the rail I fitted that yesterday IMG_4992.thumb.JPG.cc20d45fbc6f8442252bdca0b9142b5c.JPGbut first I fitted the new injectors which are a 1250cc with the stainless internals IMG_4993.thumb.JPG.3d5e8700427e6c3f1a1a1568b51f3956.JPGall 6 fitted into the rail and ready go into the car IMG_4994.thumb.JPG.d9cdc0294bc7d9641c627cfe96b108f4.JPGand fitted to the engine
Which also required a new fuel press regulatorIMG_4995.thumb.JPG.47f18ed9168164626879d5fb4819e180.JPGso I went with an ever reliable turbosmart one
IMG_4996.thumb.JPG.2c5a060bfcb50d50d9242c67dcda4531.JPGand mounted in the car, it was nice of Nissan to supply a bolt hole in the perfect spot
  • Like 1
Spent quite a bit of time over the last couple of days doing the fuel lines from front to back, it starts as a -8 from the tank and runs to the engine bay into the fuel filter, where it then splits into twin -6 and heads up to either end of the fuel railIMG_5076.thumb.JPG.3bdd561cb1ed8aa0eefd57cd3bb52a50.JPGIMG_5075.thumb.JPG.3ae8b07fc79e8e2ddffa83ce3ecff0ec.JPGthen comes out of the center of the rail to the pressure regulator IMG_5023.thumb.JPG.df50bdff7b0cdc10a6653532474b10ce.JPGI used the port where the pcv use to be for the vacuum signal and the original port for the pressure reg now only does the the map sensor
Had to trim a little bit to get the hoses on to the top hat and also ran all new wiring for the 2 fuel pumps and fuel gauge IMG_5033.thumb.JPG.74b3f74c7ca44f59c9e5b76fedf50b3f.JPGand after the cover was put back on with all the wiring tapped up it looks like it was done by Nissan IMG_5034.thumb.JPG.2532bf35c77255fa9e8fc9b2944d7e8a.JPG
  • Like 9
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
