3 hours ago, r32-25t said:
Ok so the reason I decided to cancel all Japan day is I was finishing off the last of the wiring and started to look at having to do the relays and fuses for the fuel pumps, thermo fans, trigger for the power steering pump and etc. after looking at the number of wires that were going into the car, I took a step back and thought nah f**k this there’s a better and much neater way to do this!!
insert pd16 (pdm) here and the problem is solved only issue is I now need to strip the wiring harness, remove the i/o 12 box from it and fit the pd16 instead
I got very lucky and it just happened they came into stock the day after I ordered it, now while this is a set back and will mean having to redo some work, it’ll end up being better for it
Surprised you didn't go the whole hog on the high-end nexus that's ECU and PDM in one! 😛
jealous of that PDM, I'm a poor man playing in a well funded man's sport... I'm stuck with relays and fuses ha ha ha!
I looked at it and worked out I’d either need to buy a nexus plus a pdm due to the the fact the nexus uses 3 of the 25amp out puts or just the pdm if I kept the elite in there
  • Like 1
No matter how many IO you have, you never have enough... Ha ha ha
The only other things I’d want would be more DPI/SPI to measure the 4 wheel speeds and do traction control. not sure my car will make enough power for it to be a real issue though
You're better off doing a GPS speed sensor vs. the wheel speed as your car would bake all 4x wheels, if the surface isn't optimum.
Having front and rear speed sensors and doing a traction strategy on that only works on FWD or RWD cars.
From someone in the GPS industry, you'd want it to be a good GPS module, with an actual accurate output (basically doing a lot of sensor fusion with gyros, compass, and accelerometers) or the TCS won't be that great.
For Brett's car the traction strategy would be for straight line attacks, so the Haltech GPS sensor would be sufficient for traction control in his application.
Fair enough, I can't see it being any where near good enough to compare GPS to wheel speed in most use. Imagine you drove under a tree in a corner, I'm sure we've all had that experience where we were apparently doing 60, then 120, then 30 in the space of a second.
I think with most all wheels drive cars you use both the wheels speeds and the gps, I agree the gps will end up useless in some situations and would be interesting to see how the system would react at those times
Most GPS modules are getting better than that, but still not great unless you're spending big big big dollars.
Biggest problem, is it relies on measuring distance, with decente enough error to make it quite difficult to detect did I really move, or just GPS error?
Which means you can have the GPS thinking you've moved when you haven't, and at the same time you've gone to launch and broken into mass wheel spin.
This is where you need a heap of sensor fusion from everything else.
GNSS and Vehicle Telematics is my niche professional area of work.
You would likely have more reliable wheel spin detection on an AWD using steering angle, TPS, and comparing the individual wheel speeds, as well as rate of acceleration, and comparing that with acceptable rate of acceleration at given speeds for given gears, and more so anticipating if it is wheelspin or not, vs using a GNSS sensor compared with wheelspeeds.
21 hours ago, TurboTapin said:
I was under the impression that Haltech does not allow the use of their GPS speed for traction control. It must be wheel speed sensors.
It definitely can, it just comes up as a speed sensor.
I just gave it a try and it's a no go without an addition wheel sensor. The error states "Traction Control for rear wheel drive requires at least one rear wheel sensor (Or drivetrain sensor) and at least one front wheel speed sensor."
You are correct!
I just played around with it myself and it shows the same error. A workaround is to just create your own Generic and apply ignition correct (as in take timing out) when there's a GPS Speed / Drive Train speed difference.
I'll end up trying this out one day as I want traction control.
    • Cheers. Skyline is back on the menu, can’t get rid of it. It’s like a child you don’t want, or herpes
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
