Soooo, I have a s2 rb25 in a stagea. Power FC, splitfires, z32 afm, td06, nismo 550cc injectors, gtr fuel, tuned at 18psi.
Has been running fine for 6 months until yesterday it has developed a misfire under load and full boost. Seems ok at very light load and cruising.
Has constant miss when you stand on it and try and rev it out, also get a lot of black smoke out back.
Knock doesn't go above 18 with this happening.
I checked injector value in pfc and it got up to 90% just once, normally around 68-70% WOT. AFM voltage with car off is 0.42v according to the power fc and 1.72v at cruise approx.
I took plugs out (bpr7es gapped at 0.7), and swapped with some other spares I had laying around (not new but known working) and made very little difference.
I sprayed all the vac lines and hose clamps with brake cleaner but no change in idle speed. I did find 1 loose hose clamp after the turbo outlet under the air filter, but after tightening that, no change has been observed.
It was dark when I got into changing the plugs so I couldn't inspect the coil packs thoroughly. Might get around to it on the weekend.
Any suggestions.
https://www.sau.com.au/forums/topic/458035-another-rb25-misfire-topic/
Cleaned afm, no change. Pulled coil pack leads 1 by 1 and idle got rough with each one. Seems to be when you get close to building boost it starts and then sputters then entire time on boost. Idles like normal, doesn't stall or dive.
That ain't going to help.
Tps voltage is 0.44v at idle. Check power to all coil pack plugs (14.19v across all 6). Unplugged afm and car died straight away.
I'm a bit stuck as to where I should check next? I went to repco and they didn't have any bcpr6es or bcpr7es on the shelf. I would have to order out of adelaide. I'm located alice springs so I can't just duck into a workshop with a dyno and it's my daily so I really wanna get this sorted
New plugs are in but only gapped at 0.8. Hesitates still coming onto boost but then clears up and revs clean through to redline. Makes the same amount of boost as normal once it gets up and goes. would pulling the gap back further make much of a difference that early in the Rev range if it clears up and revs clean after about 7psi?
Idles perfectly, and drives off boost as it did beforehand.
Also checked timing, 20deg btdc cold and fuel filter is new.
Hasn't got any leaks that I can see, no smoke from and where when it's running.
Edited by fmlycar
Just ask an R31 owner.
I don't understand. What is this. Will it fit in my RB30? just looking for a bit more power from my completely standard auto NA 1985 R31 that has 385,000 on the clock. Want to spend as little as possible thanx.
  • Like 1
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
