Done two heater hoses now, been lucky both times to only happen as I was getting home and losing very minor amounts of coolant.
Looking to get all done now to put my mind at ease, trying to get up behind the starter motor is an absolute nightmare.
  • Like 1
  • 1 month later...
Gday Fellas
There has been alot happening in my life so the GTR has been on the back burner
A mate invited me over to Sydney to help out with Motive DVD GTR drag battle and I have to say what an experience. Got to visit some cool performance shops and meet some really switched on owners/tuners
CRD, JEM, Micks Motorsport, Motor Sports Mechanical and Maatouks racing to name a few. Everyone is unique in how they do things with the GTRs but wow..... the smack talk..... that was probably the best part hahahahaha
I was lucky enough to meet and be able to spend a large amount of my time with Kyle from 1320videos
We both spent alot of time getting ourselves lost trying to find workshops and site seeing hahahaha
On the first day there I managed to get us lost around the north rocks area after trying to find some food and a phone shop for Kyle lol
When I returned to Perth Andrew from Motive DVD invited me to the V8 supercars to help out with the drifting side of things. That was alot of fun and I managed to meet some more amazing people
Another great opportunity was being able to show the East Coast crew what the West Coast is all about I brought 6 copies of my good friends Magazine across for the guys to check out the name of the magazine is FORGED. This mag has a diverse range of vehicles from American muscle, JDM, Aussie muscle and motorcycles. Its a very well presented mag and if anyone is interested I can organize some copies ☺
  • Like 1
Hi Frostyboy,
I just ended up buying exactly the same suspension kit from Fulcrum. Thanks for letting me know.
They did not give me quite as good a deal as you got though.
Looking forward to installation, both yours and mine. It will be great to get some feedback from you once fitted
Cheers
Matt
Edited by tangomatt
  • Like 1
Hi Frostyboy,
Cheers
Matt
Thats awesome mate when are you planning on fitting them up?
Righto Fellas
I'm thinking about selling the -5 turbos and going for a single setup I'm after some advice suggestions for turbo selection
I want the car to be an all rounder but I would like it to have some serious straight line speed.... I know it will make it harder to drive on a race track but for me I need that feeling of acceleration and speed
Hey Brad,
The drag orientated GTRs can certainly tempt you to chase more POWER. I was at the GTR fest in Sydney and liked what I saw on the drag strip.
Regarding suspension, I might actually end up going with BC racing Coilovers.
Matt
  • Like 1
  • 3 weeks later...
Well I wanted to purchase a turbo kit that would see me onto the high Nines however there was just nothing in my budget
I found a nice 2nd hand kit in Sydney that will be suited to my needs for the time being and fitted into my budget [emoji7]
A Precision 6262 on a spoton fabricated T4 split pulse manifold turbo smart wastegate and less than 2000kms on kit
Hopefully it was a wise decision to go 2nd hand
  • Like 1
  • 1 month later...
Well not good news this happened
Cooling system is completely sludged with engine oil
There is no water in the engine oil
The cooling system isn't pressurising and the oil cooler isn't bypassing either
I'm thinking cracked block
    • Update 3: Hi all It's been a while. Quite a lot of things happened in the meantime, among other things the car is (almost) back together and ready to be started again. Things that I fixed or changed: Full turbo removal, fitting back the OEM turbo oil hardlines. Had to do quite a bit of research and parts shopping to get every last piece that I need and make it work with the GT2860 turbos, but it does work and is not hard to do. Proves that the previous owner(s) just did not want to. While I was there I set the preload for the wastegates to 0,9bar to hopefully make it easier for the tuner to hit the 370hp I need for the legal inspections that will follow later on. Boost can always go up if necessary. Fitted a AN10 line from the catch can to the intake hose to make the catchcan and hopefully the cam covers a slight vacuum to have less restrictive oil returns from the head and not have mud build up as harshly in the lines and catch can. Removed the entire front interior just shy of the dashboard itself to clean up some of the absolutely horrendous wiring, (hopefully) fix the bumpy tacho and put in LED bulbs while I was there. Also put in bulbs where there was none before, like the airbag one. I also used that chance to remove the LED rpm gauge on the steering column, which was also wired in absolute horror show fashion. Moved the 4in1 Prosport gauge from sitting in front of the OEM oil pressure gauge to the center console vents, I used a 3D printed vent piece to hold that gauge there. The HKB steering wheel boss was likely on incorrectly as I sometimes noticed the indicator reset being uneven for left vs. right. In the meantime also installed an airbag delete resistor, as one should. Installed Cube Speed premium short shifter. Feels pretty nice, hope it'll work great too when I actually get to drive. Also put on a fancy Dragon Ball shift knob, cause why not. My buddy was kind enough to weld the rust hole in the back, it was basically rusted through in the lowermost corner of the passenger side trunk area where the wheel arch, trunk panel and rear quarter all meet. Obviously there is still a lot of crustiness in various areas but as long as it's not rusted out I'll just treat and isolate the corrosion and pretend it's not there. Also had to put down a new ground wire for the rear subframe as the original one was BARELY there. Probably a bit controversial depending on who you ask about this... but I ended up just covering the crack in the side of the engine block, the one above the oil feed, with JB Weld. I used a generous amount and roughed up the whole area with a Dremel before, so I hope this will hold the coolant where it should be for the foreseeable future. Did a cam cover gasket job as the half moons were a bit leaky, and there too one could see the people who worked on this car before me were absolute tools. The same half moons were probably used like 3 times without even cleaning the old RTV off. Dremeled out the inside of the flange where the turbine housing mates onto the exhaust manifolds so the diameter matches, as the OEM exhaust manifolds are even narrower than the turbine housings as we all know. Even if this doesn't do much, I had them out anyways, so can't harm. Ideally one would port-match both the turbo and the manifold to the gasket size but I really didn't feel up to disassembling the turbine housings. Wrapped turbo outlet dumps in heat wrap band. Will do the frontpipe again as well as now the oil leak which promted me to tear apart half the engine in the first place is hopefully fixed. Fitted an ATI super damper to get rid of the worn old harmonic balancer. Surely one of the easiest and most worth to do mods. But torquing that ARP bolt to spec was a bitch without being able to lock the flywheel. Did some minor adjustments in the ECU tables to change some things I didn't like, like the launch control that was ALWAYS active. Treated rusty spots and surface corrosion on places I could get to and on many spots under the car, not pretty or ideal but good enough for now. Removed the N1 rear spats and the carbon surrounding for the tailpipe to put them back on with new adhesive as the old one was lifting in many spots, not pretty. Took out the passenger rear lamp housing... what do you know. Amateur work screwed me again here as they were glued in hard and removing it took a lot of force, so I broke one of the housing bolts off. And when removing the adhesive from the chassis the paint came right off too. Thankfully all the damaged area won't be visible later, but whoever did the very limited bodywork on this car needs to have their limbs chopped off piece by piece.   Quite a list if I do say so myself, but a lot of time was spent just discovering new shit that is wrong with the car and finding a solution or parts to fix it. My last problem that I now have the headache of dealing with is that the exhaust studs on the turbo outlets are M10x1.25 threaded, but the previous owner already put on regular M10 nuts so the threads are... weird. I only found this out the hard way. So now I will just try if I can in any way fit the front pipe regardless, if not I'll have to redo the studs with the turbos installed. Lesson learned for the future: Redo ALL studs you put your hands on, especially if they are old and the previous owners were inept maniacs. Thanks for reading if you did, will update when the engine runs again. Hope nothing breaks or leaks and I can do a test drive.
    • No those pads are DBA too  but they have colors too. I look at the and imo the green "street" are the best.
    • I’m not sure what happened I told them about sonic tunes free OTS tune and the next the I know .. I was booted..   To funny
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
