Replied to your PM,
I am in, however, we need to plan for if it has to be posted from a central location and how much that will cost ontop. Also does this mat include the clips required to fix them to the bonnet? If I remember correctly they are just push ins.
Hadouken, They are just push in, and if you have a proper remover tool [available from Supercheap etc for under $10] you will be able to re use the ones you have. But I will ask if they come with the mat anyway. I also seem to remember blister packs of similar clips at Repco and Supercheap, not sure if they are the right size though.
Postage, I think the supplier [based in Melbourne] is going to handle that, not me. There could be opportunity for Vic people to pick up......I'll need to confirm.
The rest of us will have to fork out a bit more for postage, there could be some cost saving if several band together and use one address for say Sydney - but I don't know.
I am in country NSW so not the best person for sorting that one out - I was always going to pay postage, I always do for anything I buy.
Yeah, mine is tattered over the fan belt area. The turbo is on a HKS cast lowmount so heat from it is not such a problem. I think its because of age [mat is 17 years old] and the fact that I'm in the country so dirt and insects and dust get flung around in the engine bay by the belts.
My 6boost is low mount but it does rise before it goes down to the turbo. I have developed quite a bit of damage in the mat around the manifold area so not sure if its the age + the heat or just the heat. Will find out the hard way I guess lol
OK here is the story so far:
Everyone has replied to my PM except R33 gtrv-spec.
Stretch GSK has pulled out and Robzilla had to when R32 mats became unavailable.
So we had 16, we now have 13. So the price will not be the cheaper$239 but the next one up $251, so $12 a mat dearer.
Tomorrow I will send out bank details and start collecting funds [sick today sorry].
Hadouken, the method is you will pay me for the mats, I will then send a bulk payment to the suppliers. This payment will NOT include any postage, handling, or packaging.
I will send each person account details for direct deposit along with enough personal information about me to hopefully give you faith in me as a person. If you still have questions PM me and I'll try to answer them.
The supplier will then arrange for the items and have them shipped to their base in Australia. Could be 4-6 weeks or so, they are using surface shipping and a cargo container to keep costs down.
Once they have the items they will contact me and I will then contact each of you in turn and tell you how to approach the supplier [account numbers, contact details and an identifying customer number].
Postage, handling and packaging will be between you and the supplier, we live in different areas so the costs will be different.
I hope that is ok with everyone, I would have liked a few things different, but I tried and the supplier thought I was making it too complex for them.
That sounds terrific Hadouken. Fingers crossed it works out like that.
And latest:
Yep, the regular BNR34 one is the same price as the other fullsize ones.
And yep, if you've got 15, then they're $239 for the fullsize, and $220 for the smaller ones.
Regards,
Daniel
Unfortunately, unless we get some late comers we will not get the $239 price, so the prices will be $251 and $232 respectively.
Could work out for me if they arrive around Christmas because I'll be in Melbourne. If postage is an arm and a leg hit me up and I'll just drive them to nsw for interested parties.
That would be awesome!
  • Like 1
Your call mate, happy to contribute, would cost me anyway.
Anyway, I've just sent out my details and banking info to all involved. Get back to me if you didn't get the PM or you need more detail.
Getting to the pointy end now!!!!
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
    • I don't care for these at all, but at least the underside looks straight and not rusty. A good basis for a long life. Many cars from Japan have been lifted with forklifts and f**ked almost irrepairably.
    • Yes, but it's not dumb or dodgy. You can build a perfectly good boost controller from a pressure reg, a relief valve (looks same same as a reg if all from Norgren or SMC, for example) and a check valve. I ran one for years. Only superceded with  EBC because I could get one for cheaps and wanted finer control.   THis mod is certainly not a sketchy boost mod, provided the boost is kept below the "spin to death" threshold of the turbos.
