I am probably going to be picking these up tomorrow. (Will be my only opportunity).
Due to the numbers I may only be able to grab a few of these and not all 8/9.
Also, if you guys want to grab the mats while I am on route then it will probably be pretty early in the morning lol. I would suspect me to hit Sydney from 3am ish.
Please voice any concerns asap.
Ok. So I picked up some mats. I ended up with 7
2 x Trident - Gtst Series 2
1 x me - R33 GTR
1 x kingtube - Gtst Series 2
1 x kil32 - R34 GTR
1 x RoB - R34 Gtt
1 x Aqua - R34 VSpec II
Scrmr for some reason yours is said to be the one on back order. Sorry but I did not pick yours up because we didn't want to risk confusion or conflict. So we stuck to the master list that import monster had.
  • Like 1
I can meet you anywhere around Sydney - Just let me know what time you plan on being in Sydney and I'll be there doesn't matter what time of the day/night as long as I know a few hours beforehand please
Thanks again for picking them up!
@kila32 Hurstville is quite a deviation to my trip. As you can see I do not literally go through Sydney. If I start to deviate for each person my already long trip will turn into an even longer one.
Guys, I am doing this free of charge. Even import monster said I should be getting beers at least :P.
Like I said from the start, meet me on route
Or come pick them up from mine.
If that does not suite you then I will arrange postage for your item at your expense.
But I would say it's safer for the mats to transfer through less hands. Otherwise it might turn into a he did this or that situation.
So far kingtube is on my list for pickup in Sydney. If anyone else wants to pick there's up then I will arrange a time and location for this mass exodus to take place.
Be warned it might be late/early and probably Sunday.
Hey bud constitution hill, near Wentworthville and seven hills. Wouldn't make you go all the way to Hurstville. Anytime will be fine mate. If you give me a location i'll come there.
Kila32 can pick mine up and I'll grab it from his place cos he's such an awesome mate :P
Same here if Kila32 and Hadouken don't mind, please drop mine off at Kila32 too, I will pick it up there.
Thanks in advance!
  • Like 1
    • That R31 was so cool. Only did Orange Park once. Scared the hell out of me.
    • Selling my TE37SLs since I've switched to smaller wheels.  They're for sale in Japan but it's pretty simple to send them overseas; USA excluded, since JPPost isn't sending there at the moment. Specs Front: 18x9.5j +22 5x114 Rear: 18x10j +20 5x114 Price: 320,000 JPY/ 3,285 AUD (current FX rate) Condition: a few scratches here and there, no bends, distortions or cracks.  Tires will not be included for international buyers, I'll get them dismounted before shipping. They're currently listed on yahoo auction and will be shipped in Japan with the tires if they sell here. Shipping costs to Aus: EMS (1-2 weeks): AUD 1,175 (current FX rate) Sea (2 months): AUD 460  (current FX rate)
    • The alloy coolant reservoir has a sight glass, so as long as I can see coolant in the sight glass it's GTG, as for PS, it isn't anything catastrophic if it gets low, and as it hasn't lost a drop since I have owned the car I cannot see it being an issue, even after putting the "big block" 2.5 in....LOL The only time it gets slightly messy is at oil changes, as the oil filter sits above the frame, and I need to use a plastic bottle with its bottom cut off to catch the flow when loosening the filter
    • Good on you for taking on the job, but it is a big one. Even if you have bolt on manifold and turbo, you will need: Post throttle pressure source to boost controller to wastegate (and FPR, and ECU/MAP sensor) Pre throttle pressure source to top of BOV(s) Oil feed - you can take that from the standard port in the middle of the block Oil return to block under the turbo - this is much trickier than it seems to route a decent/wide pipe past the manifold. You really can't use rubber hose because it is way too hot there, and also the oil out of the turbo core is a bit frothy so it needs to have a decent diameter Water feed - you can take that from the standard port in the rear of the block. Water return - mine runs to a T into the heater box return, just make sure you don't create a high point making bleeding hard. All of those lines should use 200 series style teflon braided hose with heat shielding because everything needs to be routed past the manifold. Also a turbo beanie is a really good idea to minimise the chance of the car catching fire (under bonnet lining in particular) You also need to decide a cam cover breathing solution as well, will you vent externally via a catch can (probably illegal) or return to the intake (plumbing required and can oil up everything over time) Keep in mind the intake and exhaust piping in the engine bay will be custom so you either need to be able to fab ally and steel or have someone you can get a car that isn't running to. Get the wideband fitting welded into the dump pipe at the same time. Also, just my opinion, a screamer pipe attracts attention and doesn't add power, I'd plumb it back if you want to be allowed to keep the car on the road. BTW do you know anything about how healthy the motor is, and what power you are targeting? Doubling or tripling the factory power on an unknown motor is a little risky. Also fuel system will need some attention (pumps, high current hanger, direct power and earth feed, injectors etc)
