Hey accountant type people...
At work we're currently on MYOB Premium v19.10 (Old desktop version) running on a Terminal Server with 5 users and 5 company files... Been holding off on moving to the cloud since hardly anything cloud based seems to be able to handle a business of our size/complexity/inter company accounts/multi-currency/etc
We're looking at moving our company files into MYOB Advanced Plus which is effectively (as far as I can tell) a cloud version of EXO and looks to have all the features we're after... but after speaking with MYOB they're quoting an estimated 150 hours to import our company files at the cost of $20,000 and then $139/user/month.... They've generously offered us a payment plan of nearly $2k/month over 12 months to spread the upfront cost out a bit...
Does this $20k this seem normal? How do they not have any tools to import from one of THEIR file types into another one of THEIR software offerings?
Are there any alternatives we should be looking at that allow for multiple currencies and multiple companies?
cheap daily rate
Zoo isn't going anywhere, seems pretty selfish of her to let you pass up tickets to anything to do something you can do any day of the week.
I'd be ending it
We spent last weekend doing my thing and I said would spend this sat with her...friend only has one spare ticket otherwise I'd be saying we're both going. I let her slide on this one, but the next I'm gonna have to go to...
But yeah it's still a shitty thing to have to pass up on it - I hope she realises this - if she happens to read these forums.
If she was a reasonable gf or just a decent human being in general she'd have no issues postponing 'her weekend' for you to accept the ticket
Fair point
I'm lucky in a lot of ways, so I guess these are the trade offs. If it costs me a box ticket once in a while, not too bad.
lol'd at forever alone invitation
Hope that was done on purpose / as a joke; if not really should have used another envelope
Nope his Mrs did the invites, thought I had a girlfriend til he informed her I'm forever alone.
Fair point
Having a mrs should never cost you box...
  • Like 1
I'll be sending my kid to the closest schools and that's it...plenty of shit kickers in good schools and plenty of bright kids in shit schools
Parenting at home > influence than parenting at school
Umm no you won't.
  • Like 1
I think actually talking to me in person, rather than making a passive aggressive post like this on the forums would have been more mature, since there's more behind the scenes to this than you're saying about it, but anyway. Edited by L33SH
ok housing / finance ppl.
found a house interested in.
it's a house and land package with Dennis family homes.
then I see this:
http://www.dennisfamily.com.au/1500-down-offer
any idea what the catch is? things to look out for?
Catch us likely interest rate. Also the personal loan for balance of deposit is probably a high rate. These things usually are ok but best to source your own financing.
You can put all your money into this and just have a redraw facility on the loan so when you find what you want you can just take the cash out but in the interim reduce your interest substantially.
I know a guy who works for Dennis family if your keen pm me your details I'll get him in touch if he is still there.
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
