So i got my water bill today, including that $100 gov't rebate Birds was talking about.
South East water managed to find $96 in "other authorities charges" to replace it with.
$72 of which was for water for local parks... WHAT THE f**k ARE RATES FOR.....
Don't login to the wasteland for one day and miss all the action!
Racist flamin mongrel... next thing you'll be calling Adam Goodes a flog
lel
Why must women post pic of hand with ring once engaged? Soooo tacky
f**kn this ^ hate the house sold sticker pics too.. slightly less hate the ones that actually SHOW the house and not just a big stupid sign
25 a month for water bill....500 a month for power...damn
Never done a status in my life, & certainly don't put work on there.
Usually the correlation between posting "sold how good am I" and real success are veryyyyy distant
Your Facebook banner is of your Lexus and Nissan with personalised plates, how does that differ from someone celebrating their ring or house purchase?
Some may even call your photo tacky?
Just let your friends have their moment of joy/accomplishment even if it's minor.
Can't we all just be happy for each other? <3
Edit: first post in new wl thread
  • Like 1
yeah each to there own I just don't see why it needs to be a photo of a hand and a ring? Why not a photo of the two together? Maybe I'm old fashioned just smacks of ATTENTION PLEASE
I don't see posting a car for example in the same light, you could argue any photo is self indulgent a Vegas photo from a holiday is that tacky? guess I'm just not down with social media gettin old an all
*hot lexus tho ey haha
Edited by alr33x
last gas bill was 280 for 2 months.. meh normal i guess
im with energy aus
added up all my 'cant live without' expenses and it totalled to almost 44k farken.. or 3.6k a month (including fuel/groceries/bills/mortgage/rates/regos) not much room for random impulse buys anymore :( #houselyf
last week after just paying motorbike rego + insurance thought i'd be sweet.. nek minit $1400 rates fml :(
Edited by UNR33L
    • I saw you mention this earlier and it raised a red flag, but I couldn't believe it was real. Yes, the vacuum signal should vary. It is the one and only load signal from the engine to the ECU, and it MUST vary. It is either not connected or is badly f**ked up in some way.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
