Liam keep in mind that a lot of people would say the same about your Pulsar and how much you've spent on it. I understand your point though!!
SR20 bro.
90's pulsars... One of the last truly small cars. Not super light, but decent power in an affordable package.
Turbo territory I understand. Putting a GTX35 on it and still being slower than Leighs GS with a tune I don't get. There's a street pulsar in NSW running 11.2's and it's not some mega-build just drag focused
hilux getting serviced today at dealership... one battery stuffed, one has corrosion on the terminals, they want to replace both. $195 each + $40 fitting.
I wanted to tell them dont bother, but too much paperwork to hand to boss for remuneration. he doesnt care, he was once happy to pay $60 for them to replace a windscreen wiper.
Not sure on quality, but $40 to fit a battery. Takes 5mins to do.
I'm just against stealerships charging whatever they want
Yeah the two (one 2wd and one 4wd) both had dual batteries
Birds, charged my battery up on the bike.. now all good again, I reckon the cold weather is screwing with the tiny battery.
Will keep it for now..
Lol that territory would leave everyone dead on the street, 4wd consistent launches
Best thing about GS is half decent power and can't get done for mods by po po
Edited by UNR33L
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
