I've hit a van's mirror once (good luck to them catching you), but you generally have more room than it looks like from third person perspective. You pick and choose your splits and weaves. Trucks are usually a no go as they always have a narrow gap between them and the car in the lane next to it.
Splitting is much safer in peak hour traffic I think, but the dangerous spots are those keep clear spaces where cars can just randomly pull out into your lane because they see cars stopped before it.
Yeah fair enough, definitely something to keep in mind, thanks!
Unless you are in Russia and have a GoPro
then it's anyone's f**king game
Speaking of, is it still illegal to have cameras attached to your helmet?
I've always thought as I watch people split to the front, don't you ever come REALLY close to knocking someones mirror off, or putting a scratch down someones quarter panel?
Yeah I've tapped a mirror at like 35km/h.. guy tooted (he was at a standstill) stopped and looked back, wasn't smashed or anything and was only an old VN commodore so kept going.
You get better and better at guaging the width, and once it gets narrow just slow it down a lot / walk it through almost. It'll take you a month or so before you even become comfortable about lane splitting big gaps but eventually you just try and find your way through, i even go down turning lanes sometimes and then just wind out in front of the straight traffic sitting at the lights.
oh and if you get stuck half way down splitting because the gap is too small at the mirrors etc. just stop inbetween the cars roll back a bit let them go and continue on your way.
Edited by UNR33L
Yeah fair enough, cos I've always held the idea that getting to the front of traffic and away from them when it goes green is one of the best tactics you can do on the road, but getting to the front of that line definitely makes me a little uneasy!
Haha Dezz just jelly cos no one cares about him riding a motorbike [emoji22]
My family and friends care about me, only they aren't a drain on my finances and don't stop me from doing whatever the f**k I want whenever the f**k I want smileyface. Jpeg
Love the old turning lane to front of lights trick. Hate it when the lights to green though and you have to cut in.
Also Matt if riding in packs it's considerate to go down the split to the front and then peel out to the side a bit to let fellow riders through to the front next to you. But you learn all that anyway.
Yes getting ahead of traffic and staying the fk away from cars altogether is a good idea most of the time. However those are just the guys who try to merge you off the road with their blind spot or plain shitty awareness.
The ones you really gotta watch for are people pulling out on you from a side street onto a main road - and they're more likely to do this to a bike on it's own with no traffic around it (in this case riding with traffic can be safer). Also, getting to the front of the lights is good, just make sure you look both ways before taking off quickly, even when your light is green, cause plenty of people run reds and a lot of motorcyclists have died this way.
I care about you Dezz
& your future
Vote1liberal.
  • Like 3
Yeah usually those right turners on a straight green light when it goes orange/red you really gotta watch for
seemed to work out alright for schumacher....
oh...
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
