So someone tried what I've been wanting to for ages, e85 + smaller pulley WITHOUT a intercooler (cos e85) and made 442rwkw. Not a bad cheap upgrade..
Should see 10s for like $2000 or less of parts on a stock car..
Edited by UNR33L
*an
stock car ($40,000) + $2000 parts
Be better off buying some decent tyres and making more use out of current power
Could pick one up for 30k with higher KMs surely, or a ute :P
Put 30k into a gtst and still run 14s
inb4 butthurt (forgot who it was who ran 14s in their 350rwkw gtst :P )
Edited by UNR33L
Birds' GTR + engine rebuild + extras + e85 = $40k = 442kw?
Should cost a lot less than that but end up with similar power
Building for response though
Barry wants me to -5 but I'm sticking with the GT-SS for now
  • Like 1
    • I saw you mention this earlier and it raised a red flag, but I couldn't believe it was real. Yes, the vacuum signal should vary. It is the one and only load signal from the engine to the ECU, and it MUST vary. It is either not connected or is badly f**ked up in some way.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
