People seem very happy with the result. What do People stand to gain from this? It doesn't further guarantee a labor win next election (well not yet anyway)
We stand to gain negative Tony Abbott... what more do you need to know?
It makes labors job a hell of a lot harder now
This... Turncoat should be able to carry LNP across the line.
not like he will be struggling anyway..
Love shorten all he can come up with is turnball is arrogant only in it for himself... Mmmm that strategy will get you into office champ.
Agree ham so I'm for it cos I'm a smart enough voter to pick a party not the mouth piece
Edited by alr33x
Shorten was prettty damn stupid to have slammed Turnbull... why on earth would he have shown his hand and who he is more weary of to the LNP as they go in to vote?
Where's all those Liberal followers that were banging on about a Government needing to be stable etc when Labor went through the same thing...
Probably still arguing that a government should be stable?
im sick of fb last night/today. everyone comes out of the woodwork to push for their favourite agendas like tony was the bottleneck holding back everyone from what they wanted.yay climate changed is saved, yay gay marriage is saved, yay womens rights are saved, yay we got to use up all the excess onions in the cupboard.
I see this as a key chance for Liberal to swing a lot of fence sitters over to their side of the playground... Lots of Mid and Lefties blame Abbott for everything wrong with Liberal, so now that he's gone a few key policy changes could make for a dramatic shift towards the Libs.
The only bad part about the spill is they can't use the "Stable Party" line anymore.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
