I'm thinking about another Evo... might grab a 9 this time.
They are great cars man. They just need a good 230+ AWKW
Skylines have ruined 2 litre engines for me
It's fine after you get used to the 2 litre
But then you get back in a Skyline and man do you notice the 500cc you're missing
I'm constantly surprised by the low end torque the 4g63t has, even before it's come onto boost (which happens very early, compared to the highflow on the 2.5)...
But it's still not a car that really makes you moist and love driving, especially at what I estimate to now be about 160awkw...
SR's are great and all... but fark the GTiR and its shims. whats the difference between a noisy GTiR head and a quiet one? apparently 2 thou (0.07mm) of shim.
i found that out this afternoon. $71 and 6 shims later. prick even charged $2 packaging and handling... i f**king picked it up.
Don't underestimate 2L.
The later focus and Mazda MPS 2L (or 2.5's for that matter) are basically built for down low.... It's just up top they waver (from factory)
Rather have the extra .5 giving torque everywhere
Maybe it's my turbo and engine combination but I love my RB25, it does so well everywhere
Lol, 334HP 230KG aussie built superbike and it's in production
that's insane
http://pgmv8.com.au/spec-sheet/
birds you wouldn't even get one brah
Edited by UNR33L
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
