VB is a strange beer, it exponentially gets better based on how hot the day is, and how cold the beer is.
This is an undisputable rule of the universe, no matter how uncomfortable.
Unless the day gets too hot to sustain human life, or even worse, the VB freezes
Also, this is really all beers
It is, but VB is kind of unique in its shittiness outside of this scenario, and its relative goodness in this scenario.
It's kind of similar to the relationship between being drunk/hungover and McDonalds
Welcome to the world of beer,
every beer is brewed to match certain conditions where it is drunk.
Same as drinking CHang in AU winter tastes like ball sweat (don;t ask how I know this) where as kicking back ona beachin summer is awsome.
try drinking a German cloudy wheat beer in middle of summer here, you struggle, where as when it freezing cold outside and you have some Spätzle works a treat.
and then there heineken, Amsterdam's beer, and I swear you must be on drugs to enjoy that.
so kick back, enjoy and make the most of what you got.
  • Like 1
new trend for Evo's at WTAC: remove the entire boot section between the rear pillars. surely its we're not far away from driving a a full carbon front, no boot, chasis rails and cage in the middle.
As of tonight mine will have twin 3" :D rumblerumblerumble
Probably remove the supercharger 'silencer' rubber thing that quiets it down too.
Get a v8 m8
Edited by UNR33L
Also VB is good in ALL scenarios.
is it to rear mount a radiator and fit a bigger turbo in?
joeyjoejoejuniorshabadoo, on 16 Oct 2015 - 11:45 AM, said:
Just saw a stanced (ish), murdered out, VF R8 with cams and and exhaust.
This makes me reconsider many things....
You sure you're a hipster?
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
