That's AUD$35,000/day... Jesus, move him out of that 5 star hotel of a hospital room and put him in a closet somewhere.
That's the first step I'd make once it's been a few months with no change.
His mansion has been turned into a medical facility with 15 full time medical staff working around the clock
12 million to save one life that may not even be saved :O
That's probably 12,000 lives somewhere in the world, but what do I know about charity
and to think Paul Walker died to help the poor children in his charity fund... its a shame they never got to see his Carrera GT
On the plus side they can all have a bit of it now
Back in my day it was called a snow plow and parallel
lol I had a fat friend in primary school who would snow plow all the way down the run
They had Australian animal names in the ski school
I got to emu
He achieved "mobile koala"
I got to emu
Yeah well I achieved Shark level at Dandenong Oasis swimming school. One below Dolphin.
Leroy
Found this in my nanna's garage
108,000km on it
Plastics have some marks on them, but body straight as an arrow and interior pretty mint like in most nanna cars. Engine bay is ridiculously clean.
Schumacher has given crazy amounts of money to charities
Leroy
108,000km on it
dayum.
new daily. E85. change carburator air filter. sorted.
I got to emu
Ryan?
I was buddied up with Adrian for that Snow Trip... was perfect since we were the same skill level (horrible) at Snowboarding and progressed at the same speed through the week (up to borderline slightly less horrible)
I dub thee, munted...
https://www.dropbox.com/s/46cg9n2ygbx0s0h/12168613_10152999017271148_671803421_o.jpg?dl=0
and now... slightly less munted, but still not something I'd use as a jacking point
https://www.dropbox.com/s/dr6r5ak70rbznni/12165934_10152999024131148_1086310009_n.jpg?dl=0
*sigh*.... Ah well, at least I'm able to bolt my guard back on again now :)
Ryan?
Gotta stop forgetting there is someone I went to primary school with here lol
How epic was that trip though...
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
