They show you all the options with their software. They may sway you to a smaller bank but the final call is yours.
I made sure they worked out the best deal with the bank(s) I wanted to do business with.
If at the end of the day you come out with the lowest interest rate at the best value (LVR) their commission is not a problem.
Thats what i did, ME bank ftw
Forgot how annoying the "day after tattoo" thing is.... f**k it must be shit for those dudes that go to bali and cop a full sleeve in the heat
Yeah it would be shit being one of those dudes
Also the heat would be uncomfortable
  • Like 2
Wow... just. .. wow...
lol
ZING!
Don't scratch it ham
That's tomorrow. It's not itching at all yet
So just had a charity collector come to door,
Charity was for deafness, he had a sheet explaining he was deaf and mute and could only communicate via Sign.
blah blah
I don't donate to door knockers as a principle.
Decline to donate and the Mute guy swears at me and walks off...
And I wonder why I don't donate to door knockers.
Anyone been to any of the qld theme parks in the last 10 years? Possibly going with someone who has never been to any. After value for money and things for 20-somethings, not too much kids stuff.
Want to do just 1 park.
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
