For those that have me on fb, all aboard the feels train :'(
That post was definitely a hard one to write..
for those that don't, dem feels when you loose dog of 15 years :(
Edited by UNR33L
  • Like 2
Put down, he deteriorated a lot in the space of about a week. From walking fine etc to going blind, loss of hearing and you could hear him struggling to breath as well, oh and he started to get nose bleeds.
Good choice. Can't stand when dog owners let their dog cling to shreds of life until absolutely everything fails.
And don't watch Marley & Me, unless you're after some catharsis...
Have lost four dogs at ripe old ages, gets harder the older you are cause you understand mortality a bit better and you have more time spent with them during important and memorable times of your life. Still have 3 alive dogs who will bring me that sadness again in the next 5-7 years.
Damn you dog y u have such short life
  • Like 1
Haha I reckon, I actually ended up taking yesterday off work I was feeling a bit shitty boss completely understood being a dog person himself.
On another note he's actually building up a sleeper old 91 cresida with a 2j in, good that he into cars constantly talking shit with him bout it, do want to drive once done
Edited by UNR33L
Sorry to hear mate. My Jack Russell is 15 years old this year. He is slightly deaf and slightly blind. Still in good health otherwise. I'm cherishing everyday with him as I know at this age they can deteriorate quickly. I just can't imagine living without him as he has been apart of my life since I was 12/13 years old.
Sorry to hear mate :( Hardest thing in the world to say goodbye to a pup. I've said goodbye to two now and it never gets any easier.
My ex took our dog when she left... They had some pretty similar traits in that they both tried to f**k anything that stood still long enough. At least the dog had loyalty.
The last time I saw my pup it was like he knew that it was going to be the last time, and he was crying and jumping all over me and licking me. There is no substitute for the love of a good dog.
  • Like 1
Does anyone give a shit when cats die?
My old boss had an actual full-tilt breakdown when her chicken died. She was a c**t so I assume the chicken died by Seppuku,
Didn't they do a study recently that essentially proved that cats are asshats? Something about dogs producing 5x as much Oxytocin as cats after playing with their human.
  • Like 1
Dogs are much more social creatures I think and the pack mentality is in their ancestry; cats tend to be solo hunters like tigers (though lions do it in groups). From what I've seen in homes with multiple pets the dogs are always sticking together and watching what each other does, whilst multiple cats sort of do their own thing.
I've never had a cat so maybe I just don't get it. I feel like if I wanted an animal that found a comfortable spot and laid there for hours without moving or making any sort of noise, occasionally scavenged for food, never cleaned up after itself and otherwise wholly ignored my presence, I'd just continue living with my current housemate.
  • Like 1
I prefer cats over dogs.
Still like dogs though, so this is a "cat is more suited to me" thing over cats being superior to dogs.
Dogs are awesome, but they do require more effort to maintain, so to speak - Which isn't for everyone.
  • Like 1
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
