yeah, they're good stuff - was the first mod I did to it 4 years ago and still going strong.
BCs on my GTR started knocking after like 10 months
i know someone that had teins on his FG and bent the lower mount where it joins to the hub bit..
Edited by UNR33L
Hahaha yeah no, don't do this.
Why not?
In all my internets, I have yet to see any product ever reviewed better than Shockworks suspension on Fords
Maybe its cause Fords handle uh, interestingly from the factory, or its Ford owners not expecting such a result.
But seriously, people act like they're the second coming of Christ, people fapping over Racepace built whatever comes nothing to the amount of praise that I read regarding these things on fords
Why not?
While you are correct, all the praise I've seen are from dudes who own S13s or AE86s or similar on chopped springs so it's a HUGE upgrade for them, same story with the Fords. I'm yet to be impressed by a set yet, always been a let down unfortunately. That's not to say that cars can't be transformed with Shockworks coilovers, I just don't think they deserve the massive following that the drifters rant on about, in my experience anyway.
True, I was just always curious what would happen if someone put some serious thought into making a XR6T or GS actually handle, with some track oriented suspension.
Like a Supra (which CAN HANDLE, there's vids of people doing John Richardsonesque times at Winton in them) I wonder if its a "Culture of ford owner" problem instead of the car itself, cause noone's really given it a big try.
As for Shockworks, heard different things about them. Housemate has a set in his S15 and every person who's ever been in it pretty much reckons they are the shit. (these are not drift spec mind you). I doubt really there's a 6 second a lap difference between Shockworks and MCA and Tien's and Cusco and BC's mind you, probably relies a lot more on the dude sitting in the seat than the specific brand of coilover chosen once you have any of the more highly regarded sets
I'd say reasonably, he's got a quite a few engines on the cards. I'd imagine he could do it sometime next week or the following though.
No rush on it, just need a touch up tune sometime.
It absolutely is a culture thing, people don't usually buy them with the intention of tracking.. just quick street cars.
This is what you CAN do to them once it's intercooled (mods I listed before) with the right track pads / suspension
He came first in his class and 7th overall out of 120 cars @ Sandown 1:25 in the vid
btw he runs shockworks too so they must be arlight..
Edited by UNR33L
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
