yeah, they're good stuff - was the first mod I did to it 4 years ago and still going strong.
BCs on my GTR started knocking after like 10 months
i know someone that had teins on his FG and bent the lower mount where it joins to the hub bit..
Edited by UNR33L
Hahaha yeah no, don't do this.
Why not?
In all my internets, I have yet to see any product ever reviewed better than Shockworks suspension on Fords
Maybe its cause Fords handle uh, interestingly from the factory, or its Ford owners not expecting such a result.
But seriously, people act like they're the second coming of Christ, people fapping over Racepace built whatever comes nothing to the amount of praise that I read regarding these things on fords
Why not?
While you are correct, all the praise I've seen are from dudes who own S13s or AE86s or similar on chopped springs so it's a HUGE upgrade for them, same story with the Fords. I'm yet to be impressed by a set yet, always been a let down unfortunately. That's not to say that cars can't be transformed with Shockworks coilovers, I just don't think they deserve the massive following that the drifters rant on about, in my experience anyway.
True, I was just always curious what would happen if someone put some serious thought into making a XR6T or GS actually handle, with some track oriented suspension.
Like a Supra (which CAN HANDLE, there's vids of people doing John Richardsonesque times at Winton in them) I wonder if its a "Culture of ford owner" problem instead of the car itself, cause noone's really given it a big try.
As for Shockworks, heard different things about them. Housemate has a set in his S15 and every person who's ever been in it pretty much reckons they are the shit. (these are not drift spec mind you). I doubt really there's a 6 second a lap difference between Shockworks and MCA and Tien's and Cusco and BC's mind you, probably relies a lot more on the dude sitting in the seat than the specific brand of coilover chosen once you have any of the more highly regarded sets
I'd say reasonably, he's got a quite a few engines on the cards. I'd imagine he could do it sometime next week or the following though.
No rush on it, just need a touch up tune sometime.
It absolutely is a culture thing, people don't usually buy them with the intention of tracking.. just quick street cars.
This is what you CAN do to them once it's intercooled (mods I listed before) with the right track pads / suspension
He came first in his class and 7th overall out of 120 cars @ Sandown 1:25 in the vid
btw he runs shockworks too so they must be arlight..
Edited by UNR33L
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
    • Well they got my money but they are not getting my gearbox !
    • It's needed for rolling idle up, and I think it is a decider on VCT also.
    • I mean, not really. Link ECU's can absolutely still have errors from the ECU thinking it's getting a sensor it's not expecting. I would imagine the speed at the ECU level in Nistune does absolutely nothing anyway? I assume the ECU does not do any fancy TC stuff with regards to front+rear wheel speed or anything of that like anyway. Someone who uses Nistune may be more fluent in it.
