This was AFTER i already bought it lol, but yeah confirmed it theres shitters around the area fetching that
Mohsen, yeah I need one of those, whats your work email addy?
minimum buy is 10
Moh tell me whatever he offered and I'll beat it by 5%
ill eat you.
How much is brand new MV Automatics one?
Would prefer brand new, but that price is very reasonable. Not a super difficult install
But yes to shift kit
customer: these cake fridges are rubbish, cakes are going rock hard in there
*spend ages testing with the manufacturer/importer, cant replicate whats happening"
customer: yeah leave them in over night and see what happens.
Is it making money?
Probably - hence it's not stupid
you can serve a bird shit fondant with a side of f**king weeds picked out of the gutter to somebody these days and theyd pay top dollar if you call it something fancy.
Think brand new they are around the $500 mark. Might tackle it myself when I move house with a proper garage haha
its not hard. just might not be much fun removing the valve body when on back underneath the car.
At least if you go brand new, there is essentially warranty, and you have something to do with your old valve body.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
