Telstra > Optus > voda virgin & all the other shit
Unit behind up for lease, man it is sheit inside. dat 80s retro
cmon sexy exchange student tenant
Edited by UNR33L
With thoughts like that, your de facto missus will have half your property in no time.
Only got 19.5 for mine 4 years back, had it up for 23k etc with no one even calling over a few months
Car is only worth as much as someone is willing to pay.. the dude could of had it up for 35k for 6 months for all we know guess he wanted a quick sale to avoid rego costs etc (dunno)
U still ride?
Yeah from time to time, reminds me I have to get my KLX back from my mate, we're gonna do the Kenda Rally I think it's in April or May, you should do it it's amazing!
yeah he still rides the cock. soz borci.
Got Emmmmmmmmmmm!!
How longs it go for? I'll have to suss it out
70kms I think? and then you can choose to do the second loop which makes it a 140km ride through the bush if you want. It's a full day event though, and ideally you camp nearby the night before.
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
