70kms I think? and then you can choose to do the second loop which makes it a 140km ride through the bush if you want. It's a full day event though, and ideally you camp nearby the night before.
Nice nice, get some motard wheels for your bike mate and come ride road shenanigans too
On the first night he spends in the White House, Donald Trump is visited by the ghost
of George Washington.
He asks him, "George, what can I do to best serve the United States?"
The ghost of George Washington responds, "Never tell a lie."
He says, "Oh, I don't think I can do that."
The next night, he is visited by the ghost of Thomas Jefferson.
He asks him, "Thomas, what can I do to best serve the United States?"
The ghost of Thomas Jefferson responds, "Do not bully the people."
On the third night, he is visited by the ghost of Abraham Lincoln.
He asks him, "Abraham, what can I do to best serve the United States?"
The ghost of Abraham Lincoln responds, "Go see a play."
long story trying to find a work shop from epping area that built a R34 GTR.
seems to be decent build
sequential box, half cage, usual suspension, custom zorst. turbos usual thing.
deceased estate so they don't have receipts only where they think he had the car had been built. circa 2010/2011
88 ENERGY LIMITEDMkt cap $206.5M
(Last 10:59 )
6.7¢3.08%
  • 6.7¢ OPEN
  • 6.8¢ HIGH
  • 6.6¢ LOW
  • $197.6K VALUE
  • 2.951M VOLUME
(20 minutes delayed)
6.7¢3.08%
  • 6.6¢ OPEN
  • 6.8¢ HIGH
  • 6.6¢ LOW
  • $164.0K VALUE
  • 2.454M VOLUME
birds pls
Spoke to an uncle of mine last weekend about it, he's a chem eng in petroleum. Was like "pfft will take years for exploration like that to be worth anything". He seems to think the Shit they have to do to make shale work is pretty ridiculous and sometimes dodgy.
down ramper
  • Like 1
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
    • You think its the AFM? I know its a common issues on R32s. I find it coincidental how this issue raised right after cleaning the fuel system. As everything except the fuel system was fine before. I tried running it with the IACV unplugged but did not notice a difference and still stalled. However, the RPM gauge is not in the cluster right now, so I will need to connect the laptop again and use Nistune to check the RPM. I will check this weekend.
