I call bullshit on this..
went from the old R888 to Achilles 123 Sport (their supposedly track tyres)
grip level dropped so fast it was not funny.
just ended up spinning tyres out of every corner.
I'm currently running the 123s. They're not a proper semi like r888. There more equivalent to a fed 595rsr and I've found they perform similarly. 595 might be a touch better.
do you have any suspension work done to the car? Swaybars, camber, castor adjustments?
Swaybars make a massive improvement in understeering/oversteering.
GTR swaybars, castor arms, camber arms
had 595rs, ku36, RE11 prior and now on RS3 I had significantly less grip with the 123s
180RWKW and just spinning them rest I could stand on the pedal and no issues.
I had RE002's once... Then my wallet got raped and won't be buying Bridgestone sports tyres ever again.
They've probably done like 3000kms in a few years, so will hang onto them until they bald like Louis CK
My experience has been quite different. 248rwkw and grip fine. Maybe the weight of the skyline helps. Dont get me wrong, they're not amazing, far from it. I was just trying to make the point that they're not an r compound.
In saying all of that, would I buy them again? Probably not. Truth be told, the only reason I did buy them is coz they where 150 a corner fitted in 265/35/18. Wallet was happy:) I think i'll be trying the rs3 next.
RS3 are getting up near R888 grip but wear so much better.
I got the 123S as I wanted AD08's but was 2 weeks out from WTAC so think there were my size left in stock!
these were cheap, and I needed tyres for SAUNats.
got a class win at that.
  • Like 1
Dodged 2 court cases for jury duty, one being a 6 week murder trail. Wew.
A short one would have been nice to experience but f**k travelling to city at 9am everyday, that shit is for suckers
Edit: spoke too soon, have to come back tomorrow for another round
